[mapserver-users] Nationalatlas Shapefile Projection
Sathiskumar Govindasamy
gsathis at yahoo.com
Thu Mar 21 21:25:30 EST 2002
Hi all,
To give a better idea about what I am trying to acheive, I have explained
little bit more in this mail than before. I wanted the mapserver to
generate the image of USA in the "lcc : Lambert Conformal Conic projection"
or "aea : Albers Equal Area" or which ever suits best for US. I have the
National Atlas US States shapefile statesp020.xxx . The following is the
map file.
NAME USA
STATUS ON
EXTENT -126 50 -66 24
UNITS METERS
SIZE 700 550
SHAPEPATH "data"
IMAGECOLOR 79 173 253
PROJECTION
"proj=lcc"
"lat_0=24"
"lat_1=50"
"lon_0=-99"
END
WEB
TEMPLATE demo.html
LOG demo.log
END
# Start of symbol definitions (we're only using a few)
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS 1 1 END
FILLED TRUE
END
# Start of layer definitions
LAYER
NAME statesp020
MAXSCALE 600000
TYPE POLYGON
STATUS DEFAULT
DATA statesp020
PROJECTION
"proj=latlong"
"ellps=clrk66"
END
CLASSITEM 'state'
CLASS
NAME 'Unwanted States'
EXPRESSION /'Virgin Island'|Puerto|Alaska/
OUTLINECOLOR 198 243 255
COLOR 198 243 255
END
CLASS
NAME 'State & Nation Boundary'
EXPRESSION /./
OUTLINECOLOR 180 180 180
COLOR 255 255 255
OVERLAYSYMBOL 'circle'
OVERLAYSIZE 2
OVERLAYOUTLINECOLOR 180 180 180
END
TOLERANCE 0
END
END
In the Map PROJECTION Section when I change the above shown on to
proj=latlong and remove lat_0 and other stuff, then the map shows up
correctly. But, when I have it as shown above, I just only see an image
with solid image color. Can someone tell me where I am making mistake ?
Thanks
Sathis
Kieran J. Ames wrote:
Sathis,
I'll share the little I know with you.
You need to investigate projections in general. Different projections render
maps in different ways. If you have ArcView (what I use), you can take your
UNPROJECTED DATA (Decimal Degrees) and PROJECT it. This will allow you to see
what happens. If you can't do that, then you might post to the group and ask
them what the best projection for this would be.
eg: if you want to show North America and NOT zoom in, you may choose one
projection over another. Tell the group what you want to accomplish and go
from
there.
HTH.
Kieran
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020321/dcf521ae/attachment.html
