[mapserver-users] mapplet causes error with IE5.5
    Maul, Andreas-Alexander
    Andreas.Maul at bgr.de
    Fri Mar 22 01:25:04 PST 2002
Seems that IE5.5 installs a buggy Java VM (Microsoft Knowledge Base Q305674)
with respect to java applets. Upgrading to a newer version of the Microsoft
VM seems to help.
Regards,
Andreas
-----Ursprüngliche Nachricht-----
Von: Maul, Andreas-Alexander [mailto:Andreas.Maul at bgr.de]
Gesendet am: Donnerstag, 21. März 2002 12:21
An: mapserver-users at lists.gis.umn.edu
Betreff: [mapserver-users] mapplet causes error with IE5.5
in my mapserver-application I use the mapplet for zooming and querying.
Sometimes (not every time) I get a gray image instead of the map when using
IE5.5 SP1 on NT 4.0 and doing the same things. The error log says:
java.lang.IllegalArgumentException
	at com/ms/awt/image/ImageRepresentation.offscreenInit
	at com/ms/awt/image/Image.<init>
	at com/ms/awt/ImageX.<init>
	at com/ms/awt/WComponentPeer.createImage
	at java/awt/Component.createImage
	at mapplet.init
	at com/ms/applet/AppletPanel.securedCall0
	at com/ms/applet/AppletPanel.processSentEvent
	at com/ms/applet/AppletPanel.run
	at java/lang/Thread.run
Does anybody have encountered this problem too? Any suggestions?
Thanks in advance,
Andreas
More information about the MapServer-users
