[mapserver-users] image problems
Lowell Filak
lfilak at medinaco.org
Fri Mar 22 10:07:51 EST 2002
This may be my fault.
Your .gif image is actually a png and your .png image is actually a jpeg with a quality factor of 0!
If you bring your image up in Imagemagick "display europe.gif" and select 'image info' you will see what I mean.
I may have the documentation wrong as to which file-type is which number in the docs. For now use $mapscript::MS_PNG & $mapscript::MS_JPEG instead of the numbers. I will try to track down what happened and correct the docs asap. The is an update of the docs due to be posted soon anyways (sent in 3-19-2002).
Lowell F.
The following message was sent by "Dylan Keon" <keon at nacse.org> on Thu, 21 Mar 2002 18:18:25 -0800.
> Now that I have the Perl mapscript module working, I tried the simple script
> to create & save images from a shapefile. I tried creating images in GIF,
> JPG, and PNG formats. You can see the results at
> www.nacse.org/~keon/temp/test.html , using the shapefile from the Europe
> example. GIF output looks great, PNG looks terrible, and I can't even get
> usable JPG output (can't view the JPGs in any program). On the web page you
> can see the parameters I used with the msSaveImage function.
> I suspect I need to compile something differently in the MapScript Perl
> module. I pasted the current configuration below (contents from Makefile).
> I don't understand why I'm even getting GIF output...I thought the latest
> version of GD (which is what I'm using) doesn't support GIFs? I must be
> using something other than GD to create GIFs. I'd really like to create
> good PNGs and JPGs...I don't care so much about GIFs. I also pasted output
> from mapserv -v below, although I think that doesn't matter since I'm not
> doing anything web-based...I'm just running the standalone Perl script for
> testing.
> I did read messages in the archive related to image quality, and GIF vs.
> PNG, but couldn't find information on my problem.
> Thanks for any help,
> Dylan
> >From mapserver_3.5/mapscript/perl/Makefile
> # DEFINE =>
> q[-DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_
> GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT]
> # INC => q[-I/usr/local/etc/mapserver_3.5 -I/usr/local/include]
> # LIBS =>
> [q[-L/usr/local/etc/mapserver_3.5 -lmap -lgd -L/usr/local/lib -l
> # NAME => q[mapscript]
> # OBJECT => q[mapscript_wrap.o]
> >From ./mapserv -v
> MapServer version 3.5 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=TTF
> INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=POSTGIS INPUT=SHAPEFILE
