[mapserver-users] ANGLE AUTO labels with TRUETYPE and LINE
features. The text isdisplayed wrong.
Steve Lime
steve.lime at dnr.state.mn.us
Mon Mar 25 16:10:39 EST 2002
Hmmmm... Assuming that MapServer calculates the right angle for a single
segment it could be a data problem. Could you share some? If a road is
segmented into many small pieces then MapServer chooses a single one to
represent the line. If that segment is much smaller than the displayed
text then even a small variation between segments *could* cause the
error. Could also be an error in MapServer. Having the data sample would
help resolve that question.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Dan Keith <bud at otsys.com> 03/22/02 02:50 AM >>>
I have a shape file containing road definitions in the form of line
segments. Using mapserver, I can draw the layer and its segments and
the labels for the highway segments. So I have no problems with my
shapefile and its interaction with mapserver.
My problem is in the appearance of the angled labels with respect to
the segments that they are labelling. Note that I am using the
mapserver feature that automatically calculates the angle (as opposed
to obtaining it from the shapefile's .dbf).
Using the ANGLE AUTO feature on the labels, I can get the label
angles to closely match the angle of the segment, but not quite.
Usually, there is a 10-degree difference in the two angles, which
causes the label to drift away or towards the road segment.
I'm wondering if others have noticed this behavior, and whether this
is something that is fixable (or controllable). I've tried various
combinations of the POSITION and OFFSET fields of the LABEL. So far,
the best I've come up with is a label positioned above the road
segment with a small amount of space between the label and the road.
I use:
LABEL
TYPE TRUETYPE
ANTIALIAS TRUE
FONT Arial
ANGLE AUTO
POSITION AUTO
COLOR 0 0 0
SIZE 8
END
I was hoping someone out there could tell me whether mapserver can be
made to behave better.
thanks,
dan keith (bud at otsys.com)
Dan "Bud" Keith - bud at otsys.com
