[mapserver-users] ANGLE AUTO labels with TRUETYPE and LINE features. The text isdisplayed wrong.
Michel M. dos Santos
michel at omnisystem.com.br
Wed Mar 27 13:24:49 EST 2002
Steve,
I have been occupied with others tasks and not reply your last mail for me
(below), but my problem still continue.
I think that Dan Keith has same problem.
I put 2 images for you see:
http://creedence.org/imagens/map.png ( done by Mapscript PHP, Mapserver
3.5, linux kernel 2.4.5 , glibc 2.2.3, apache 1.3.22) and
http://creedence.org/imagens/arc.png ( done by ArcExplorer 2.0 for
windows milenium, only for comparision).
Boot images are done with same data (shapefile e dbf file).
The shapfile is type LINE and the labels doesn't follow the symbol in
mapserver.
LABEL
ANGLE AUTO
BUFFER 2
COLOR 0 0 0
FONT "arial"
MAXSIZE 16
MINDISTANCE 300
MINSIZE 6
PARTIALS TRUE
POSITION CC
SIZE 10
TYPE TRUETYPE
END
This is a big problem for me. My client likes the final result with my job
with mapserver , but doesn't like these labels wrongs.
Thanks a lot,
[]'s
-------------------------8<-------------------------------------
Re: [mapserver-users] symbol of the streets
Data: Tue, 12 Mar 2002 15:27:14 -0600
De: "Steve Lime" <steve.lime at dnr.state.mn.us>
Para: <frank.koormann at intevation.de>, <michel at omnisystem.com.br>
Cópia: <mapserver-users at lists.gis.umn.edu>
Auto rotation of labels requires lines. Are the lines being labeled also
being displayed? Doesn't
seem like it to me. If you actually draw those what does the map look
like?
Steve
Stephen Lime
Data & Applications Manager
Em Seg 25 Mar 2002 18:10, Steve Lime escreveu:
> Hmmmm... Assuming that MapServer calculates the right angle for a single
> segment it could be a data problem. Could you share some? If a road is
> segmented into many small pieces then MapServer chooses a single one to
> represent the line. If that segment is much smaller than the displayed
> text then even a small variation between segments *could* cause the
> error. Could also be an error in MapServer. Having the data sample would
> help resolve that question.
> Steve
> Stephen Lime
> Minnesota DNR
> 500 Lafayette Road
> St. Paul, MN 55155
> 651-297-2937
> >>> Dan Keith <bud at otsys.com> 03/22/02 02:50 AM >>>
> I have a shape file containing road definitions in the form of line
> segments. Using mapserver, I can draw the layer and its segments and
> the labels for the highway segments. So I have no problems with my
> shapefile and its interaction with mapserver.
> My problem is in the appearance of the angled labels with respect to
> the segments that they are labelling. Note that I am using the
> mapserver feature that automatically calculates the angle (as opposed
> to obtaining it from the shapefile's .dbf).
> Using the ANGLE AUTO feature on the labels, I can get the label
> angles to closely match the angle of the segment, but not quite.
> Usually, there is a 10-degree difference in the two angles, which
> causes the label to drift away or towards the road segment.
> I'm wondering if others have noticed this behavior, and whether this
> is something that is fixable (or controllable). I've tried various
> combinations of the POSITION and OFFSET fields of the LABEL. So far,
> the best I've come up with is a label positioned above the road
> segment with a small amount of space between the label and the road.
> I use:
> LABEL
> TYPE TRUETYPE
> ANTIALIAS TRUE
> FONT Arial
> ANGLE AUTO
> POSITION AUTO
> COLOR 0 0 0
> SIZE 8
> END
> I was hoping someone out there could tell me whether mapserver can be
> made to behave better.
> thanks,
> dan keith (bud at otsys.com)
