[mapserver-users] Re: your mail
Lowell.Filak
lfilak at medinaco.org
Tue Mar 26 08:03:47 EST 2002
When you run the cgi through your browser and the reference map fails to
load, if you look at the page source or at /var/log/httpd/error_log on the
apache server do you see any errors?
Lowell F.
On Tue, 26 Mar 2002, Gumli deMoria wrote:
> Hi all,
> I'm new with mapserver and I'm still in installing and configuring phase.
> Also I'm new with linux so my problems are even bigger.
> I've obtained mapserv CGI and placed it on apache/cgi-bin/ directory.
> I've tryed a demo for mapserver but I have problems with it. The page load
> but the reference map doesn't appear. I have compiled with support for gif,
> png, jpg, etc.
> when I execute ./mapserv in the command line in the cgi-bin directory I
> obtain this:
> >./mapserv
> Content-type: text/html
> <HTML>
> <HEAD><TITLE>MapServer Message</TITLE></HEAD>
> <!-- MapServer version 3.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> SUPPORTS=TTF INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=SHAPEFILE -->
> <BODY BGCOLOR="#FFFFFF">
> loadMap(): Web application error. CGI variable "map" is not set.
> </BODY></HTML>
> I followed the "MapServer Unix Compilation and Installation HOWTO" and there
> is told that after ./mapserv I should obtain the following instead of wich I
> obtain:
> ./mapserv
> This script can only be used to decode form results and
> should be initiated as a CGI process via a httpd server.
> So, I don't know where's the problem. Any help will be welcome.
> Thanks.
> Carlos.
> _________________________________________________________________
> Join the worlds largest e-mail service with MSN Hotmail.
> http://www.hotmail.com
