[mapserver-users]: wrong results querybypoint
Lowell.Filak
lfilak at medinaco.org
Tue Mar 26 08:24:58 EST 2002
Try adding 1 to the result during the dbase query. The shape index starts
at 0 but the dbase file records start at 1. Hopefully that should give you
the correct result.
Lowell F.
On Tue, 26 Mar 2002, Peter wrote:
> Hi Listers,
> doing a querybypoint the zoom to the queried polygon is doing well, but
> the information is wrong. It gives the wrong result. Here's the code:
> Thanks a lot
> Peter
> $queryresult = @$map -> queryByPoint ($querypoint, MS_SINGLE, -1);
> if ($queryresult == MS_SUCCESS) {
> /* Bei einem Erfolg: Ergebnisse aus dem gewünschten Layer holen*/
> $resultlayer = $map -> getLayerByName ('objekte');
> /* Uns interessiert nur das erste (i.e. nullte) Resultat */
> $theresult = $resultlayer -> getResult (0);
> $shapefile = ms_newShapefileObj ('C:\Programme\Apache
> Group\Apache\htdocs\immogis3w\code\data\objekte', -1);
> $resultshape = $shapefile -> getShape ($theresult -> shapeindex);
> $resultbounds = $resultshape -> bounds;
> /* Karte auf diese Extents zoomen */
> $map -> setExtent ($resultbounds -> minx-80, $resultbounds ->
> miny-80,$resultbounds -> maxx+80, $resultbounds -> maxy+80); = CORRECT
> ZOOM!!!
> $numresults = $resultlayer -> getNumResults ();
> $resultclass = $resultlayer -> getClass (0);
> $dbasefile = dbase_open ("C:\Programme\Apache
> Group\Apache\htdocs\immogis3w\code\data\objekte.dbf", 0);
> $dbrecord = dbase_get_record_with_names ($dbasefile, $theresult ->
> shapeindex);
> $Dummy = $dbrecord['ID'];
> printf ("%f<br>", $Dummy); = WRONG RESULT!!!
