[mapserver-users]: SUM wrong results querybypoint
Peter
blackmail at snafu.de
Tue Mar 26 08:37:23 EST 2002
Hi Lowell,
that was that!
the code working is:
$dbrecord = dbase_get_record_with_names ($dbasefile, $theresult ->
shapeindex+1);
The list rocks!!! Thanks a lot!
Peter
Lowell.Filak wrote:
>Try adding 1 to the result during the dbase query. The shape index starts
>at 0 but the dbase file records start at 1. Hopefully that should give you
>the correct result.
>Lowell F.
> On Tue, 26 Mar 2002, Peter wrote:
>>Hi Listers,
>>doing a querybypoint the zoom to the queried polygon is doing well, but
>>the information is wrong. It gives the wrong result. Here's the code:
>>Thanks a lot
>>Peter
>> $queryresult = @$map -> queryByPoint ($querypoint, MS_SINGLE, -1);
>> if ($queryresult == MS_SUCCESS) {
>> /* Bei einem Erfolg: Ergebnisse aus dem gewünschten Layer holen*/
>> $resultlayer = $map -> getLayerByName ('objekte');
>>/* Uns interessiert nur das erste (i.e. nullte) Resultat */
>> $theresult = $resultlayer -> getResult (0);
>> $shapefile = ms_newShapefileObj ('C:\Programme\Apache
>>Group\Apache\htdocs\immogis3w\code\data\objekte', -1);
>> $resultshape = $shapefile -> getShape ($theresult -> shapeindex);
>> $resultbounds = $resultshape -> bounds;
>> /* Karte auf diese Extents zoomen */
>> $ma
>>p -> setExtent ($resultbounds -> minx-80, $resultbounds ->
>>miny-80,$resultbounds -> maxx+80, $resultbounds -> maxy+80); = CORRECT
>>ZOOM!!!
>> $numresults = $resultlayer -> getNumResults ();
>> $resultclass = $resultlayer -> getClass (0);
>> $dbasefile = dbase_open ("C:\Programme\Apache
>>Group\Apache\htdocs\immogis3w\code\data\objekte.dbf", 0);
>>shapeindex);
>> $Dummy = $dbrecord['ID'];
>> printf ("%f<br>", $Dummy); = WRONG RESULT!!!
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020326/42174857/attachment.html
