[mapserver-users] questions (FWD)
Thomas E. Burk
teb at mallit.fr.umn.edu
Sat Mar 30 09:57:07 EST 2002
------------- Begin Forwarded Message -------------
Date: Fri, 29 Mar 2002 17:37:31 -0500
To: @lists.gis.umn.edu
Subject: questions
Mime-Version: 1.0
Content-Transfer-Encoding: 7bit
X-vsuite-type: e
Dear mapserver users!
Thank you in advance for your help and Your opinion on the
stuff below:
I have to develop a module that should display the US map with
each state
colored according to some supplied value and Indivudual states,
where each county are
colored according to some changeable value as well.
I selected the mapserver a few days ago and it works for the
trial application I created.
I will appreciate your advice in the following:
To color the maps with varying colors it looks like I have the
following options:
1. assigning the individual shapefiles to classes in layers in
the Mapfile
and changing the 'color' value (overwriting the file) each time
the
changes occur in the system. The server is loading map file on
each request and it
should work.
I do not know whether it is the most efficient option. Also I
do not like
very much overwriting the files onthe disk.
2. tying the color value to the state or county attributes of
shapes records
in *.dbf file. After which setting the color by using MapObj
APIs.
This option involves either modifying the mapserver or writing
the scrips (perl or
php with the mapscript)
3. Writing a set of APis based on the mapserver/gd/shapelib
freeware (it is already done
by mapserver community) and coding the application
again through php or something like this.
4. Something that I am not aware of, that will do it in a much
more elegant and simpler
fashion.
Again , thank you very much for your advice.
With Best regards,
Alexander Shostko,
shostko at ureach.com
------------- End Forwarded Message -------------
