[mapserver-users] msSearchDiskTree(): Errors
Stephen Woodbridge
woodbri at swoodbridge.com
Sat Mar 30 11:09:56 EST 2002
Chris et al,
Thanks,this is good to know,
but I don't think this is the case with the data set I just built. And
if it is the case with this dataset, then I need to know what is the
problem so I can fix it. I just built the tileindexes based on the
exitance of the shp files. So I don't know how there can be missing
data.
If there is missing data then,
HOW do I figure out what files are missing?
Mapserver is clearly complaining about something, but the error message
is not adequate to figure out the problem.
imap at chesapeake.net wrote:
> Steve,
> I dont think these are errors... this occurs when you are missing
> files in your tiles. (ie. county tile missing a feature layer)
> They occur in the MS_ERRORLOG, but dont effect processing
> unless you have not defined IGNORE_MISSING_DATA at compile time.
> This has been in the code for a long time...
> There should probably be some logic coded into the source to
> get rid of these messages if IGNORE_MISSING_DATA is defined. It
> tends to fill up the logfile.
> -Chris Stuber (mapsurfer)
> Stephen Woodbridge wrote:
> > Hi all,
> > I searched the archives, but could not find anything useful on this
> > error message:
> > Sat Mar 30 12:31:35 2002 - msSearchDiskTree(): Unable to access file.
> > I have a bunch of tileindexes referenced in my mapfile, I have checked
> > all the files and directories to make sure they are accessible. I turned
> > on error logging to a file but got nothing more useful than what was get
> > prionted in the scripts.
> > How do I find out what file msSearchDiskTree() is complaining about?
> > I am running ms_3.5 release. I tried 3/20 nightly and could not get any
> > thing to display. the error is alway on the php/mapscript line
> > $image = $map->draw();
> > I rebuilt all my tileindexes and there shptrees.
> > So, I am at a total loss on how to proceed.
> > Thanks again for any help or suggestions you might offer.
> > -Steve
