[mapserver-users] Class limit and Mapscript
Homme Zwaagstra
hrz at geodata.soton.ac.uk
Wed May 8 15:10:04 EDT 2002
Dear List,
I've noticed that MS_MAXCLASSES in map.h defines a limit of 50 classes per layer. Using
PHP mapscript I've written some code that exceeds this limit with the result that I get a
crash with "Fatal error: MapServer Error in msSearchDiskTree()". I'm wondering whether the
fact that I'm exceeding the limit means that there's way to solve my problem other
than changing MS_MAXCLASSES and recompiling.
What I am trying to do is dynamically set the size of each point in a layer and to do this it
seems I have to create a class relating specifically to that point. Or am I wrong? The code
relating to the creation of the classes follows:
--- code snippet ----------------------------------------
# $reports is an associative array containing data relating to specific points in a layer
$i = 1; # counter
foreach ($reports as $code => $value) { # iterate through data creating a class for each point
print "$i [$code] = $value<br/>\n"; # debugging output
$class = ms_newClassObj($layer); # instantiate new class object
$size = ($value * 3) + 10; # create multiplier
$class->set('size', $size); # set the size of the symbol
$class->set('maxsize', $size);
$class->set('minsize', $size);
$class->set('symbol', $sym_id);
$class->set('name', $code);
$class->set('outlinecolor', $outline);
$class->set('color', $colour);
$class->setexpression("('[N2]' eq '$code')"); # set expression so that only the relevant point is drawn
$i++;
Thanks in advance for any insights!
Homme Zwaagstra.
