[mapserver-users] 3.6 (development)
Richard Greenwood
rich at GreenwoodMap.com
Fri May 10 09:09:55 EDT 2002
I built 3.6 from May 4th nightly.tar and my 3.5 CGI applications worked
fine without any modification. The best (only?) place to track changes is:
http://www2.dmsolutions.ca/mapserver/dl/mapserver_ChangeLog.txt
Regarding you query about Mandrake 8.1, I'm running 8.1 w/o problems, so I
wouldn't blame it on Mandrake per se. I'd check your GD build and install.
best of luck,
Rich
At 12:39 AM 5/10/2002 -0400, you wrote:
>OK, I am getting ate up here with 3.6 from the CVS
>I may have missed previous posts about mapfile changes, but
>so far I have snagged on ANTIALIAS TRUE, FILLED TRUE and
>LABEL font SIZE xxx Can someone give a rundown on the mapfile
>parameter changes for 3.6? Did we get rid of TRUE/FALSE
>again in the new version? Not sure whats up with Label
>font SIZE, maybe a param name change or something???
>I wish I had more time to fumble thru the mapfile/symbolset
>changes, but I am pressed for time and need to get something
>working here, but would be nice to know more about the new
>changes...
>Regards,
>Chris Stuber (mapsurfer)
