[mapserver-users] Mapfile Enhancement?
Paul Ramsey
pramsey at refractions.net
Tue May 21 17:11:06 EDT 2002
Stephen Woodbridge wrote:
> In ArcExplorer there is a feature that allows you to assign class breaks
> to theme properties based on a numeric field attribute and a color ramp.
> Has this be contemplated for 3.6?
> I am generating drivetime polygons that are like contour rings and would
> like to be able to display each ring as a different color. I also
> believe that a few other people have requested a similar feature for
> polygons so they could display different polygons as different colors
> from the same shape file.
> I can work a round it by creating a bunch of class entries.
Perhaps I am misunderstanding, but creating a bunch of class entries
seems like the actual solution and not a work around. e.g.:
LAYER
CLASS
EXPRESSION (([ATTR] > 0) AND ([ATTR] <= 20))
END
END
LAYER
CLASS
EXPRESSION (([ATTR] > 20) AND ([ATTR] <= 40))
END
END
LAYER
CLASS
EXPRESSION ([ATTR] > 40)
END
END
This is a categorical color ramp. If you look in an ArcIMS AXL file, for
example, on a categorical color ramped field, you will see ArcXML
entries which essentially do exactly the above.
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
