[mapserver-users] Mapfile Enhancement?
Alan McNeil
alan at rlkhydro.com
Wed May 22 11:35:03 EDT 2002
How about using the same parameter parser as the TEXT command for the COLOR
command? Then you could say something like COLOR [RED] [GREEN] [BLUE]. Probably
the COLOR command should be modified to allow a single hex number (ie 0xFFFFFF)
as a direct specification of the color.
Next thing you know people will be asking for direct specification of Munsell
colors, HSV, and Crayola Crayon colors.
-AL
On Tue, 21 May 2002, Stephen Woodbridge wrote:
> This is another good idea that I had also thought of. I might prove
> interesting if not problematic for mapserver because of limited color
> palette. I though of having a attribute field the contained the hex
> encoded RGB color like in HTML color definitions and then have mapserver
> render the object in that color. So if I had an attribute field say
> "COLOR" that had a value of "FF0000" the object would be rendered in
> red.
> -Steve
