[mapserver-users] Instalation problems...
Jim Burnett
r00t at ntelos.net
Mon Nov 4 10:49:25 EST 2002
Have you tried installing 1.8x? I had problem with Gd2.0.x and installed
GD1.8 and re-compiled mapserver and it worked fine.
-jim
----- Original Message -----
To: "Jim Burnett" <r00t at ntelos.net>
Cc: <mapserver-users at lists.gis.umn.edu>
Sent: Monday, November 04, 2002 10:33 AM
Subject: Re: [mapserver-users] Instalation problems...
> Jim Burnett wrote:
> >Which version of GD do you have?
> GD 2.0.4
> >What linux distro?
> RH 7.2
> >-jim
> >From: "Dragos Lipan" <dlipan at pcrai.ro>
> >To: <mapserver-users at lists.gis.umn.edu>
> >Sent: Monday, November 04, 2002 5:36 AM
> >Subject: [mapserver-users] Instalation problems...
> >>When trying to install mapserver 3.6.1,
> >>after all necesary prerequisites,
> >>I found for
> >>./configure --with-gd=/usr --with-postgis --with-gdal --with-proj \
> >> --with-ogr --with-wmsclient
> >>the following
> >>loading cache ./config.cache
> >>checking for gcc... (cached) gcc
> >>checking whether the C compiler (gcc ) works... yes
> >>checking whether the C compiler (gcc ) is a cross-compiler... no
> >>checking whether we are using GNU C... (cached) yes
> >>checking whether gcc accepts -g... (cached) yes
> >>checking for c++... (cached) c++
> >>checking whether the C++ compiler (c++ ) works... yes
> >>checking whether the C++ compiler (c++ ) is a cross-compiler... no
> >>checking whether we are using GNU C++... (cached) yes
> >>checking whether c++ accepts -g... (cached) yes
> >>checking for ranlib... (cached) ranlib
> >>checking for flex... (cached) flex
> >>checking for yywrap in -lfl... (cached) yes
> >>checking for bison... (cached) bison -y
> >>checking if compiler supports -R... (cached) no
> >>checking if compiler supports -Wl,-rpath,... (cached) yes
> >>checking for exp in -lm... (cached) yes
> >>checking how to run the C preprocessor... (cached) gcc -E
> >>checking for ANSI C header files... (cached) yes
> >>checking for strcasecmp... (cached) yes
> >>checking for strncasecmp... (cached) yes
> >>checking for strdup... (cached) yes
> >>checking whether we should include JPEG support...
> >>checking for jpeg_read_header in -ljpeg... yes
> >> using libjpeg from system libs.
> >>checking which version of GD to use...
> >> using libgd from -L/usr/lib -lgd
> >>checking where FreeType is installed...
> >>checking for FT_Init_FreeType in -lfreetype... yes
> >> using libfreetype -lfreetype from system libs.
> >>checking where Zlib is installed...
> >>checking for zlibVersion in -lz... yes
> >> using libz from system libs.
> >>checking where PNG is installed...
> >>checking for png_init_io in -lpng... yes
> >> using libpng from system libs.
> >>checking for gdImageGif in -lc... no
> >>checking for gdImagePng in -lc... no
> >>checking for gdImageJpeg in -lc... no
> >>checking for gdImageWBMP in -lc... no
> >>checking for gdImageStringFT in -lc... no
> >>checking for gdImageStringTTF in -lc... no
> >>checking for gdImageString16 in -lc... no
> >>checking for gdImageGifPtr in -lc... no
> >> using GD ( -DUSE_GD_SWAP_XY) from /usr.
> >>checking whether we should include PDF support...
> >>checking for PDF_setlinewidth in -lpdf... no
> >>checking for PDF_setrgbcolor in -lpdf... no
> >>checking for PDF_moveto in -lpdf... no
> >>checking for PDF_curveto in -lpdf... no
> >>checking for PDF_show_xy in -lpdf... (cached) no
> >> libpdf not found... PDF support not included.
> >>checking whether we should include TIFF support...
> >>checking for TIFFOpen in -ltiff... yes
> >> using libtiff from system libs.
> >>checking whether we should include EPPL7 support...
> >> including EPPL7 support.
> >>checking whether we should include PROJ.4 support...
> >>checking for pj_init in -lproj... yes
> >>checking for pj_transform in -lproj... yes
> >>checking for pj_latlong_from_proj in -lproj... yes
> >> using PROJ.4 from system libs.
> >>checking whether we should include thread safe support...
> >> thread safe support disabled.
> >>checking whether we should include ESRI SDE support...
> >> ESRI SDE support not requested.
> >>checking whether we should compile in MPATROL support...
> >> MPATROL support not requested.
> >>checking whether we should include OGR support...
> >>checking for gdal-config... (cached) /usr/local/bin/gdal-config
> >>checking for OGRRegisterAll in -lgdal.1.1... (cached) yes
> >> using OGR from system libs.
> >>checking if GDAL support requested... yes
> >>checking if PostGIS support requested... yes
> >>checking for pg_config... (cached) /usr/local/pgsql/bin/pg_config
> >>yes, user supplied pg_config
> >>checking if OracleSpatial support requested... no
> >>checking whether we should include WMS support...
> >> OGC WMS compatibility enabled (-DUSE_WMS).
> >>checking whether we should include WMS Client Connections support...
> >>checking for libwww-config... (cached) /usr/local/bin/libwww-config
> >> found libwww version 5.4.0
> >> OGC WMS Client Connections enabled (-DUSE_WMS_LYR).
> >>checking for potential conflict between system regex and rxposix...
> >>checking for regexec in -lrx... (cached) no
> >>Compiling with -DIGNORE_MISSING_DATA.
> >>checking whether we should enable debug features...
> >>checking for PHP/MapScript module options...
> >> PHP/MapScript module not configured.
> >>creating ./config.status
> >>creating Makefile
> >>but make ... resulsts as
> >>gcc -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ
> >>-DUSE_PROJ_API_H -DUSE_WMS -DUSE_WMS_LYR -DUSE_TIFF -DUSE_JPEG
> >>-DUSE_GD_SWAP_XY -DUSE_OGR -DUSE_GDAL -DUSE_POSTGIS
> >>-I/usr/include -I/usr/local/include -I/usr/local/include
> >>-I/usr/local/pgsql/include -I/usr/local/include
> >>-I/usr/local/include/w3c-libwww -DHAVE_CONFIG_H shp2img.o -L. -lmap
> >>-L/usr/lib -lgd -ljpeg -lfreetype -lpng -lz -ltiff -ljpeg -lfreetype
> >>-lpng -lz -lproj -ljpeg -L/usr/local/lib -lgdal.1.1
> >>-L/usr/local/pgsql/lib -lpq -L/usr/local/lib -lwwwxml -lxmltok
> >>-lxmlparse -lwwwinit -lwwwapp -lwwwhtml -lwwwtelnet -lwwwnews -lwwwhttp
> >>-lwwwmime -lwwwgopher -lwwwftp -lwwwfile -lwwwdir -lwwwcache -lwwwstream
> >>-lwwwmux -lwwwtrans -lwwwcore -lwwwutils -lmd5 -ldl -lm -o shp2img
> >>/usr/lib/libwwwapp.so: undefined reference to `HTZLib_inflate'
> >>/usr/lib/libgd.so: undefined reference to `XpmReadFileToXpmImage'
> >>collect2: ld returned 1 exit status
> >>make: *** [shp2img] Error 1
> >>HTZLib_inflate I can avoid,
> >>but I really can't do anything with libgd.so ..
> >>Any ideas?
> >>TIA
> >>Dragos Lipan
> >>TI
> >>Parcul National Piatra Craiului
> >>2223 Zarnesti
> >>Str. Raului. 27
> >>Tel/fax (04)(068)223008
> >>dlipan at pcrai.ro
> Dragos Lipan
> TI
> 2223 Zarnesti
> Str. Raului. 27
> dlipan at pcrai.ro
