[mapserver-users] Instalation problems...
Dragos Lipan
dlipan at pcrai.ro
Mon Nov 4 10:53:57 EST 2002
ok everything works fine now ... I gave up on configuring fdal :(( and
rebuild the freetype lib
... after recompiling gd, it works finally :)
Thank you very much.
Dragos Lipan wrote:
> Jim Burnett wrote:
>> Which version of GD do you have?
> GD 2.0.4
>> What linux distro?
> RH 7.2
>> -jim
>> ----- Original Message ----- From: "Dragos Lipan" <dlipan at pcrai.ro>
>> To: <mapserver-users at lists.gis.umn.edu>
>> Sent: Monday, November 04, 2002 5:36 AM
>> Subject: [mapserver-users] Instalation problems...
>>> When trying to install mapserver 3.6.1,
>>> after all necesary prerequisites,
>>> I found for
>>> ./configure --with-gd=/usr --with-postgis --with-gdal --with-proj \
>>> --with-ogr --with-wmsclient
>>> the following
>>> loading cache ./config.cache
>>> checking for gcc... (cached) gcc
>>> checking whether the C compiler (gcc ) works... yes
>>> checking whether the C compiler (gcc ) is a cross-compiler... no
>>> checking whether we are using GNU C... (cached) yes
>>> checking whether gcc accepts -g... (cached) yes
>>> checking for c++... (cached) c++
>>> checking whether the C++ compiler (c++ ) works... yes
>>> checking whether the C++ compiler (c++ ) is a cross-compiler... no
>>> checking whether we are using GNU C++... (cached) yes
>>> checking whether c++ accepts -g... (cached) yes
>>> checking for ranlib... (cached) ranlib
>>> checking for flex... (cached) flex
>>> checking for yywrap in -lfl... (cached) yes
>>> checking for bison... (cached) bison -y
>>> checking if compiler supports -R... (cached) no
>>> checking if compiler supports -Wl,-rpath,... (cached) yes
>>> checking for exp in -lm... (cached) yes
>>> checking how to run the C preprocessor... (cached) gcc -E
>>> checking for ANSI C header files... (cached) yes
>>> checking for strcasecmp... (cached) yes
>>> checking for strncasecmp... (cached) yes
>>> checking for strdup... (cached) yes
>>> checking whether we should include JPEG support...
>>> checking for jpeg_read_header in -ljpeg... yes
>>> using libjpeg from system libs.
>>> checking which version of GD to use...
>>> using libgd from -L/usr/lib -lgd
>>> checking where FreeType is installed...
>>> checking for FT_Init_FreeType in -lfreetype... yes
>>> using libfreetype -lfreetype from system libs.
>>> checking where Zlib is installed...
>>> checking for zlibVersion in -lz... yes
>>> using libz from system libs.
>>> checking where PNG is installed...
>>> checking for png_init_io in -lpng... yes
>>> using libpng from system libs.
>>> checking for gdImageGif in -lc... no
>>> checking for gdImagePng in -lc... no
>>> checking for gdImageJpeg in -lc... no
>>> checking for gdImageWBMP in -lc... no
>>> checking for gdImageStringFT in -lc... no
>>> checking for gdImageStringTTF in -lc... no
>>> checking for gdImageString16 in -lc... no
>>> checking for gdImageGifPtr in -lc... no
>>> using GD ( -DUSE_GD_SWAP_XY) from /usr.
>>> checking whether we should include PDF support...
>>> checking for PDF_setlinewidth in -lpdf... no
>>> checking for PDF_setrgbcolor in -lpdf... no
>>> checking for PDF_moveto in -lpdf... no
>>> checking for PDF_curveto in -lpdf... no
>>> checking for PDF_show_xy in -lpdf... (cached) no
>>> libpdf not found... PDF support not included.
>>> checking whether we should include TIFF support...
>>> checking for TIFFOpen in -ltiff... yes
>>> using libtiff from system libs.
>>> checking whether we should include EPPL7 support...
>>> including EPPL7 support.
>>> checking whether we should include PROJ.4 support...
>>> checking for pj_init in -lproj... yes
>>> checking for pj_transform in -lproj... yes
>>> checking for pj_latlong_from_proj in -lproj... yes
>>> using PROJ.4 from system libs.
>>> checking whether we should include thread safe support...
>>> thread safe support disabled.
>>> checking whether we should include ESRI SDE support...
>>> ESRI SDE support not requested.
>>> checking whether we should compile in MPATROL support...
>>> MPATROL support not requested.
>>> checking whether we should include OGR support...
>>> checking for gdal-config... (cached) /usr/local/bin/gdal-config
>>> checking for OGRRegisterAll in -lgdal.1.1... (cached) yes
>>> using OGR from system libs.
>>> checking if GDAL support requested... yes
>>> checking if PostGIS support requested... yes
>>> checking for pg_config... (cached) /usr/local/pgsql/bin/pg_config
>>> yes, user supplied pg_config
>>> checking if OracleSpatial support requested... no
>>> checking whether we should include WMS support...
>>> OGC WMS compatibility enabled (-DUSE_WMS).
>>> checking whether we should include WMS Client Connections support...
>>> checking for libwww-config... (cached) /usr/local/bin/libwww-config
>>> found libwww version 5.4.0
>>> OGC WMS Client Connections enabled (-DUSE_WMS_LYR).
>>> checking for potential conflict between system regex and rxposix...
>>> checking for regexec in -lrx... (cached) no
>>> Compiling with -DIGNORE_MISSING_DATA.
>>> checking whether we should enable debug features...
>>> checking for PHP/MapScript module options...
>>> PHP/MapScript module not configured.
>>> creating ./config.status
>>> creating Makefile
>>> but make ... resulsts as
>>> gcc -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ
>>> -DUSE_PROJ_API_H -DUSE_WMS -DUSE_WMS_LYR -DUSE_TIFF -DUSE_JPEG
>>> -DUSE_GD_SWAP_XY -DUSE_OGR -DUSE_GDAL -DUSE_POSTGIS
>>> -I/usr/include -I/usr/local/include -I/usr/local/include
>>> -I/usr/local/pgsql/include -I/usr/local/include
>>> -I/usr/local/include/w3c-libwww -DHAVE_CONFIG_H shp2img.o -L.
>>> -lmap -L/usr/lib -lgd -ljpeg -lfreetype -lpng -lz -ltiff -ljpeg
>>> -lfreetype -lpng -lz -lproj -ljpeg -L/usr/local/lib -lgdal.1.1
>>> -L/usr/local/pgsql/lib -lpq -L/usr/local/lib -lwwwxml -lxmltok
>>> -lxmlparse -lwwwinit -lwwwapp -lwwwhtml -lwwwtelnet -lwwwnews
>>> -lwwwhttp -lwwwmime -lwwwgopher -lwwwftp -lwwwfile -lwwwdir
>>> -lwwwcache -lwwwstream -lwwwmux -lwwwtrans -lwwwcore -lwwwutils
>>> -lmd5 -ldl -lm -o shp2img
>>> /usr/lib/libwwwapp.so: undefined reference to `HTZLib_inflate'
>>> /usr/lib/libgd.so: undefined reference to `XpmReadFileToXpmImage'
>>> collect2: ld returned 1 exit status
>>> make: *** [shp2img] Error 1
>>> HTZLib_inflate I can avoid,
>>> but I really can't do anything with libgd.so ..
>>> Any ideas?
>>> TIA
>>> Dragos Lipan
>>> TI
>>> Parcul National Piatra Craiului
>>> 2223 Zarnesti
>>> Str. Raului. 27
>>> Tel/fax (04)(068)223008
>>> dlipan at pcrai.ro
Dragos Lipan
TI
2223 Zarnesti
Str. Raului. 27
dlipan at pcrai.ro
