[mapserver-users] Poblem with labeling (cache?)
David Monterroso Cabello
pyro-x at ixine.com
Wed Nov 6 10:01:04 EST 2002
Hi all,
Recently i noticed a strange problem with labeling in my street maps
app. My application render 3 maps using php mapscript, first i open de
map file and then i render the same map using different extents. The
problem show up when only the first map image get labels, the first
image is ok, but the next ones get the same labels that were rendered in
the first image.
I've attached the 3 pictures so you can see what im talking
about. Anyways, if i re-read the map file with ms_newMapObj() each
time the problem go away, but i would like not to do that cause that
means mapscript engine have to do a re-read and re-parse the map file,
isn't it?.
I'm using mapserver 3.6.1 with PHP mapscript.
Many thanx in advance
David.
Type: image/gif
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20021106/c49edd43/1036585187289252.gif
Type: image/gif
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20021106/c49edd43/1036585187289253.gif
Type: image/gif
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20021106/c49edd43/1036585187289254.gif
