[mapserver-users] Possible bug? or bad configuration!
Dragos Lipan
dlipan at pcrai.ro
Fri Nov 8 01:37:54 EST 2002
Daniel Morissette wrote:
>Dragos Lipan wrote:
>>Testing several old .map files, I noticed that if
>>I use in a Layer Section the keyword 'Size', the output will have all
>>the time black color,
>>no matter what COLOR 193 23 25 I used.
>>It might be a bug (not sure ... can be a misconfiguration???).
>>I'm using Mapserver 3.6.3.
>There is no 'SIZE' keyword in the LAYER object, but there is one in the
>CLASS object, so I assume that you meant that if a class had a SIZE
>value set then the color would always be black.
Sorry for the lack of precision, of course is on the CLASS object.
>This is odd for sure, but color and size are used in classes all the
>time and they usually work, so perhaps the problem would be with your
>build of MapServer: first make sure you do not have an old
>/usr/local/lib/libmap.am (if you have one then delete it), then rerun
>configure and run 'make clean; make' in the mapserver directory and try
>again with the new executables.
Checked. No libmap at all on the entire disk.
>If this still happens after that then please file a bug in the MapServer
>bugzilla with a sample mapfile that reproduces this. (A ZIP with a tiny
>mapfile with associated data that reproduces this would be best)
Did it.
>Daniel
Thank you very much for the amability.
Dragos
Dragos Lipan
TI
Parcul National Piatra Craiului
2223 Zarnesti
Str. Raului. 27
Tel/fax (04)(068)223008
dlipan at pcrai.ro
