[mapserver-users] layer transparent
Ivan Paoluzzi
tesimap at hotmail.com
Sat Nov 9 08:46:49 EST 2002
Sorry,
but I have forgotten to tell that I'm using, in this project, mapserver 3.5
I'm searching a method to render transparent a layer of polygons such as
TRANSPARENCY in mapserver 3.6
Ivan
>From: "Martin, Daniel" <DMartin at erac.com>
>To: 'Ivan Paoluzzi' <tesimap at hotmail.com>,
>mapserver-users at lists.gis.umn.edu
>Subject: RE: [mapserver-users] layer transparent
>Date: Fri, 8 Nov 2002 15:27:27 -0600
>There are two ways to go about that, AFAIK. They are quite different, but
>it depends on what effect you are trying to achieve.
>One is to use a PIXMAP symbol with a setting for TRANSPARENT:
>SYMBOL
> NAME 'dither-black-25_percent'
> TYPE PIXMAP
> TRANSPARENT 1
>END
>In that case, the color in the palette index 1 would be transparent.
>Newer versions of MapServer (not sure, I think 3.6+) support a setting in
>the layer object:
>LAYER
> NAME "MY LAYER"
> TRANSPARENCY 30
>This sets the layer at 30% of full.
>Hope that helps,
>Dan
_________________________________________________________________
Solo posta desiderata. Solo promozioni mozzafiato. MSN Offerte Speciali
http://www.msn.it/msnservizi/so/
