[mapserver-users] beginner getting started
Thomas P. Colson
tpcolson at nexussoft.com
Mon Nov 11 10:40:49 EST 2002
and here's the link
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScriptRH72
-----Original Message-----
Sent: Monday, November 11, 2002 10:40 AM
To: mapserver-users at lists.gis.umn.edu
Subject: RE: [mapserver-users] beginner getting started
Here's a good link for RH installation:
Hint: Don't install RH with RH PHP installed. Hint 2: Make sure Apache is up and running before you compile any of the libraries. Hint 3: Make sure you get GIF image support running, and tested with the PHP info script. You'll pull your hair out trying to get the demos to work without GIF support (they can work, with a lot of code hacking).
Sent: Monday, November 11, 2002 10:30 AM
To: Thomas P. Colson; Seth Rodriguez; mapserver-users at lists.gis.umn.edu
Although I've read in this list that MapServer runs on Windows, in the long run, I'd have to agree with Tom that you should try a Linux platform ( or UNIX if you have access to one ).
>From your description I take you might not have experienced Linux/UNIX yet. It does cost 'a little' more to set up a UNIX than a Linux system. If you have a spare computer you can either download or buy ( inexpensively ) installation CD for Linux. Red Hat is a popular commercialized brand. I personally run Mandrake 8.0 with MapServer running either using shape files or directly retrieve data from Oracle. It is not 'that' difficult to set it up.
From: Thomas P. Colson [mailto:tpcolson at nexussoft.com]
Sent: Monday, November 11, 2002 9:16 AM
To: Seth Rodriguez; mapserver-users at lists.gis.umn.edu
What are your Linux Skills? It works much better "out of the box" on Red Hat. I'd stay away from "Winders".
From: Seth Rodriguez [mailto:srodriguez at maguiregroup.com]
Sent: Monday, November 11, 2002 8:40 AM
Subject: [mapserver-users] beginner getting started
I have been asked by the boss to develop some new marketable GIS skills. Our company does a lot of work in the transportation industry. One task in our transportation work is to do public involvement. So I have suggested developing project websites with web-based project mapping using MapServer, which I was introduced to at an ArcView training. To assess the usability of the software, I wanted to implement a test to show the boss. Unfortunately, my programming experience is limited to a bit of avenue, AML, VB, and html, none of which I would say I am fluent in. Fortunately, the description of the software notes that programming is not required for basic use.
I apologize for my novice questions, but I am having some problems off the bat. I have downloaded the newest version (3.6.3) and the demo, but have not found any executables in the zips. I am assuming that this is due to a corrupted download. I also noticed that the software is known to run on 95, 98, and NT. I am running XP on my machine. Will this be a problem? I can move to another machine if needed.
I hope that I am not biting off too much with this task. Luckily for me, I am a quick learner. Would anyone out there please consider taking a young, ambitious consultant under their wing to help him impress his boss? I will be forever grateful.
Thanks for your time.
Seth Rodriguez
Environmental Scientist
GIS Analyst
Maguire Group Inc.
564 Forbes Avenue, Suite 1212
Pittsburgh, PA 15219
(412) 281-6393
(412) 281-7908 FAX
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20021111/05cb7ec1/attachment.html
