[mapserver-users] I give up; WMS (client)
Brian Fischer
bfischer at mpls.houstoneng.com
Tue Nov 12 12:10:34 EST 2002
Murray,
Here are a couple of WMS layers I have been using. I hope this might
help you out.
# RRBDINviewer.map
MAP
NAME "RRBDINViewer"
EXTENT 345221 5009802 896629 5620242
SIZE 500 500
FONTSET "d:/rrbdin/tools/mapserv36/fonts/fontset.list"
SYMBOLSET "d:/rrbdin/tools/mapserv36/symbols/symbol.sym"
SHAPEPATH "d:/rrbdin/tools/mapviewer/shapefiles"
UNITS METERS
Projection
"init=epsg:26914"
END
WEB
IMAGEPATH "d:/rrbdin/tools/mapserv36/temp_mapserv/"
TEMPLATE rrbdinviewer_main.html
Metadata
wms_title "RRBDIN"
# WMS_onlineresource
"http://www.rrbdin.org/tools/mapserv36/cgi-bin/mapserv.exe?map=tools/map
viewer/rrbdinviewer.map"
END
MINSCALE 1000
MAXSCALE 7000000
EMPTY '../../mapviewer/query_miss.html'
END
LAYER
NAME bathmetry
METADATA
"wms_title" "Elevation/Bathymetry"
"wms_srs" "EPSG:42304 EPSG:4269 EPSG:4326"
END
TYPE RASTER
STATUS OFF
CONNECTIONTYPE WMS
CONNECTION
"http://www2.dmsolutions.ca/cgi-bin/mswms_gmap?VERSION=1.1.0&REQUEST=get
MAP&LAYERS=bathymetry,prov_bound,drainage,drain_fn,popplaces&SRS=EPSG:42
304&BBox=-2200000,-712631,3072800,3840000&Transparent=false&FORMAT=image
/gif"
PROJECTION
"init=epsg:42304"
END
End #layer DmSolutions
LAYER
NAME "usgslandsat7"
METADATA
"wms_title" "US_Landsat7"
"wms_srs" "epsg:4326"
"wms_connectiontimeout" "1000"
END
TYPE RASTER
STATUS OFF
CONNECTIONTYPE WMS
CONNECTION
"http://gisdata.usgs.net/servlet/com.esri.wms.Esrimap?ServiceName=USGS_W
MS_LANDSAT7&VERSION=1.0.0&REQUEST=map&Layers=LANDSAT7&SRS=EPSG:4326&REAS
PECT=false&Format=gif"
PROJECTION
"init=epsg:4326"
END
END #layer usgslandsat7
Brian
-----Original Message-----
Sent: Tuesday, November 12, 2002 10:58 AM
To: Mapserver-Users (E-mail)
Subject: [mapserver-users] I give up; WMS (client)
Uncle!
I have been trying for days now to retrieve a layer (any layer) into my
MapServer application from a remote MapServer source. I am sure I have a
correctly compiled programme:
MapServer version 3.6.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT INPUT=TIFF INPUT=EPPL7 INPUT=SDE INPUT=OGR
INPUT=GDAL
INPUT=SHAPEFILE
and I am sure all the paths, including the one to the epsg file, are
correctly specified. My server end gets its stuff from an SDE layer and
the
display is fine. I use the same programme, the same templates, and
differ
only in these lines in the map file
in server WEB object
< METADATA
< WMS_TITLE "Surficial geology - Milne Inlet, NU"
< WMS_ONLINERESOURCE
"http://s5-ott-issbeta/Scripts/mapserv.exe?map=C%3a%2fInetpub%2fsurficia
l%2f
maps%2fmilne.map&"
--- in client WEB object
> METADATA
> WMS_ONLINERESOURCE
"http://w5-ott-isstsd2/Scripts/mapserv.exe?map=C%3a%2fInetpub%2fwwwroot%
2fma
pserv_site%2fmilne.map&"
and, in server end LAYER object (slightly altered with x's)
< DATA "GSC10196200002PLY,shape"
< CONNECTION "xxx.xxx.nrcan.gc.ca,port:5151,null,xxxx,xxxx"
< CONNECTIONTYPE sde
< NAME milne
--- client end LAYER object
> CONNECTION
l%2f
maps%2fmilne.map&REQUEST=GetMap&VERSION=1.1.0&FORMAT=image/png&LAYERS=mi
lne&
TRANSPARENT=true"
> CONNECTIONTYPE WMS
> NAME milne
It does not work. I get a blank image (but the scalebar is fine). On the
advice of a knowledgable colleague I tried connecting to a demo layer
using
this for the LAYER object
LAYER
NAME "GMap_WMS_Demo_Server-park"
STATUS ON
TYPE RASTER
CONNECTIONTYPE WMS
CONNECTION
"http://www2.dmsolutions.ca/cgi-bin/mswms_gmap?SERVICE=WMS&VERSION=1.1.0
&LAY
ERS=park&QUERY_LAYERS=park&FORMAT=image/gif&TRANSPARENT=TRUE"
UNITS METERS
SIZEUNITS PIXELS
TOLERANCE 3
TOLERANCEUNITS PIXELS
METADATA
"wms_srs" "EPSG:4269 EPSG:4326"
"wms_title" "Parks"
"wms_boundingbox" "EPSG:4269 -2346800 -67422.39844 2840370
3830120"
"wms_queriable" "1"
"wms_latlonboundingbox" "-173.433 41.4271 -13.0481 83.7466"
END
PROJECTION
"proj=lcc"
"ellps=WGS84"
"lat_1=49"
"lat_2=77"
"lat_0=49"
"lon_0=-95"
"x_0=0"
"y_0=0"
END #End layer projection
END #End of raster layer "GMap_WMS_Demo_Server-park"
Again a nice scalebar but a blank image.
Can anyone suggest why this image is blank, or can anyone point me in
the
direction of how to debug something like this? I am most grateful to all
the
kind help I have received.
<<Murray, Ross.vcf>>
