[mapserver-users] msOpenSHPFile(): Unable to access file.
m.spring at gmx.de
m.spring at gmx.de
Wed Nov 13 12:29:36 EST 2002
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
woodbri at swoodbridge.com writes:
> So this implies that you have shape files at:
> /usr/local/httpd/htdocs/frauke/daten/states.shp
> /usr/local/httpd/htdocs/frauke/daten/states.shx
> /usr/local/httpd/htdocs/frauke/daten/states.dbf
If you do not want to make your shapes downloadable, you should
definitely find another place outside the webserver document tree for
them!
Regarding your problem:
I do never use SHAPEPATH, but instead repeat the path inside the DATA
token which I always quote.
Hope this helps
Markus
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.0.6 (GNU/Linux)
Comment: Processed by Mailcrypt 3.5.6 and Gnu Privacy Guard <http://www.gnupg.org/>
iD8DBQE90owAxxUzQSse11ARAjoLAJ96ZWZ4a4+whkpConxvucbk6zaIqQCfZYda
5UBcg2O/kERp7ETgqDWjVzA=
=tGuw
-----END PGP SIGNATURE-----
