[mapserver-users] oracle8.1.7 and mapserver
nida Khan
nida at webstar.co.uk
Fri Nov 15 09:48:26 EST 2002
I gave wrong example! :(
here is the right example
layer defination
LAYER
NAME counties
TYPE polygon
STATUS default
MAXSCALE 1000000
CONNECTIONTYPE oraclespatial
CONNECTION 'scott/tiger at PHAR'
DATA "GEOM from counties"
CLASS
NAME 'county'
COLOR 220 224 230
OUTLINECOLOR 0 0 0
END
END
where I have counties table with a column geom
very anxious!
Regards
Nida.
----- Original Message -----
To: nida Khan ; mapserver-users at lists.gis.umn.edu
Sent: Friday, November 15, 2002 1:34 PM
Subject: RE: [mapserver-users] oracle8.1.7 and mapserver
Nida:
You need to compile MapServer with oraclespacial.
Your Oracle RDBMS needs to have Spacial option loaded. Hopefully you've already got this part, it is a good learning curve if you havn't.
What web server are you using? You might need to modify the configuration a little.
Once you have all the correct environment and settings it WILL work. I'm running MapServer on a Mandrake Linux server accessing Oracle 8.0.5 data on a UnixWare server through CGI.
Yu-Hsin
-----Original Message-----
Sent: Friday, November 15, 2002 6:29 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [mapserver-users] oracle8.1.7 and mapserver
Hi Everyone,
Is there anyway to connect to Oracle 8.1.7 database on Solaris via Mapserver?
I've compiled Mapserver with Postgress, but have no idea how to do it for Oracle now!
I would really appreciate if anyone can guide me to right documentation or just give me some codes!!!!
Looking forward for your replies
Regards
Nida.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20021115/dcf66b48/attachment.html
