[mapserver-users] MapServer + Weather Data
Paul Ramsey pramsey at refractions.net
Sat Nov 16 22:50:14 PST 2002
I am guessing you could do it with some clever SQL, which turns your
weather information into values which map to your display requirements.
You would want the wind speed mapping to letters which correspond to the
symbols in your font set. You would then use that field as your
LABELITEM in an annotation layer. You would also get the direction, and
use that as the LABELANGLEITEM. The result should be the symbols you
want, rotated in the correct directions.
Daryl Herzmann wrote:
> Hi,
>   Back in August, I posted a question about getting weather data into
> mapserver, in particular, wind barbs.
> http://mapserver.gis.umn.edu/wilma/mapserver-users/0208/msg00335.html
> I finally poked around with this task this evening and am horribly stuck :)
>   I have attached the ESRI Weather font output, which is what I assume I
> should be using to build wind barbs?  So I query my wind speeds out of the
> PostGIS database which is an attribute and am able to use the "weather"
> font to label the data points, but the symbols are wrong for the values.
>   So my question is how to associate the integer value of wind speed
> in knots with the font?
>   (hehe, then my next question is how to include visibility too, since
> this font file has that capability.)
> Thanks,
>   Daryl
More information about the MapServer-users mailing list
