[mapserver-users] MapServer + Weather Data
Jan Hartmann
jhart at frw.uva.nl
Mon Nov 18 07:03:46 EST 2002
Daryl,
I have been plotting TrueType symbols in two ways: MapServer only and
MapServer/PostGIS. Perhaps people know better solutions; if so let me know.
-----------------> MapServer only: <--------------------
1) Define your symbols in a separate symbol file:
symbol
name 'wind1'
type truetype
font 'Esri_Weather'
character "b" # symbol number in character map
end
symbol
name 'wind2'
type truetype
font 'Esri_Weather'
character ""=c"
end
and so on for all the symbols you need
2) In the main section of your MapFile, indicate where your fonts and
symbols live:
FONTSET "<path to fontset file>"
# see: http://mapserver.gis.umn.edu/doc36/fontset.html
SYMBOLSET "<path to the symbol file you made before>"
3) Create an annotation layer in your MapFile and create classes for
each wind speed you want to have mapped:
class
expression "([wind_speed] = 1)"
symbol "wind1"
size ...
color ...
end
class
expression "([wind_speed] = 2)"
symbol "wind2"
size ...
color ...
end
and so on
-------------------> MapServer/PostGIS <---------------------------
1) In your PostGIS DATA statement, create a subselect to convert wind
speeds to the character-numbers of the Esri_Weather font symbols you
want to use:
select the_geom from
(select oid
case when wind_speed = 1 then chr(98)
when wind_speed = 2 then chr(99)
end as wind_speed_symbol
from wind_table
) as foo
2) Create an annotation layer in your MapFile with just one class:
layer
LabelItem wind_speed_symbol
class
label
type truetype
font Esri_Weather
size ...
color ...
end
end
end
As Paul says, you can just add a field like wind_direction in the DATA
select and use LABELANGLEITEM to orientate the symbol.
Regards,
Jan Hartmann
> Daryl Herzmann wrote:
>> Hi,
>> Back in August, I posted a question about getting weather data into
>> mapserver, in particular, wind barbs.
>> http://mapserver.gis.umn.edu/wilma/mapserver-users/0208/msg00335.html
>> I finally poked around with this task this evening and am horribly
>> stuck :)
>> I have attached the ESRI Weather font output, which is what I assume
>> I should be using to build wind barbs? So I query my wind speeds out
>> of the PostGIS database which is an attribute and am able to use the
>> "weather" font to label the data points, but the symbols are wrong for
>> the values.
>> So my question is how to associate the integer value of wind speed
>> in knots with the font?
>> (hehe, then my next question is how to include visibility too, since
>> this font file has that capability.)
>> Thanks,
>> Daryl
Jan Hartmann
Department of Geography
University of Amsterdam
jhart at frw.uva.nl
