[mapserver-users] Couldn't run perl mapscript under Apache
krung
krung at cad.go.th
Mon Nov 18 13:36:02 EST 2002
>Those two messages are just warnings and do not keep the script from working properly unless you are running mod_perl or use strict.
OK, I'll try doing with mod_perl later coz I never used it on Linux, only on Windows.
>After you ran the script at the command line you should have had an images/test.png file created at the same time.
>Did you?
Yes.
>If you open it in your browser does it look like what you expected?
No.
>Note that when you ran it at the command line you should have seen the html header, start tag, & end tag printed to the screen also.
>Did you?
Yes.
>Puneet is correct in that your script still doesn't contain start_html or end_html.
I'd tried it already.
>Lowell F.
