[mapserver-users] Mapserver and PostgreSQL
Kieran J. Ames
kames at keyspanenergy.com
Thu Nov 21 14:24:46 EST 2002
I'd not heard of shp2pgsql before.
Is there a windows version of shp2pgsql around? I looked in my Mapserver
directory and don't see it.
Thanks,
Kieran
Jan Hartmann wrote:
> Arjen Vrielink wrote:
> > Hello All,
> > I was wondering if I could connect to a PostgreSQL database directly
> > from Mapserver. The problem is that we have SuSE 8.1 doing the
> > installation of PostgreSQL so we don't have the pg src code on our
> > machine which you need to install / compile PostGIS. Not being convinced
> > about the benefits of POSTGIS after reading the documentation I decided
> > I could live without it. That is, until I tried to get Mapserver connect
> > to my Postgres db --> There are no error messages but I don't get the
> > layer displayed either (I use an ESRI shapefile which I dumped to SQL
> > code for testing). So my basic question is: do I really need Postgis
> > (and what are the benefits of Postgis anyway)? if I really need postgis,
> > I will get the postgres source code and install it manually on my linux
> > box.
> > Suggestions would be appreciated, thanks
> > using:
> > Linux 2.4.something
> > PostgreSQL 7.2
> > Mapserver 3.6
> > (PHP 4.3.0RC1)
> > arjen,
> > SarVision
> > Wageningen
> > The Netherlands
> Arjen,
> You are not obliged to use PostGIS . MapServer will run quite happily on
> its own (with great functionality). However, if you are on a Linux
> platform, I would certainly advise to add PostGreSQL with the PostGIS
> extension (you cannot connect MapServer to PostgreSQL without it). Reasons:
> - You can import every database from Windows (including Access) into
> PostgreSQL by a few mouseclicks using pgAdmin. These data can be
> uniformly queried by full-featured SQL and combined with GIS maps
> - You can import most vector GIS files by using shp2pgsql or ogr2ogr and
> let MapServer build maps based on them. Most important, you can create
> maps based on combinations of geographical queries (e.g. everything
> within a certain distance of selected objects), and regular attribute
> queries (e.g. everything with a certain name).
> For this you need the PostgreSQL source code. Personally I don't use the
> locations of standard distributions like SUSE for this: it's very
> difficult to remember where they put things. I download the source code
> under my $HOME directory and configure everything with ./configure
> --prefix=$HOME. After that you need to install the PostGIS extension. If
> you managed to compile and install MapServer, this should be no problem
> at all. Perhaps you should wait a few days until PostgreSQL 7.3 is released.
> Hope this helps.
> Vriendelijke groeten,
> Jan
> Jan Hartmann
> Department of Geography
> University of Amsterdam
> jhart at frw.uva.nl
