[mapserver-users] compile problems
Frank Warmerdam
warmerdam at pobox.com
Fri Nov 22 22:56:38 EST 2002
Caffeinate The World wrote:
> I get this compile error in both latest stable and nightly built:
> --- from nightly built
> ns01$ gmake
> gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ
> -DUSE_PROJ_API_H -DUSE_WMS_S
> VR -DUSE_TIFF -DUSE_JPEG -DUSE_GD_SWAP_XY -DUSE_POSTGIS
> -I/usr/local/include -I
> /usr/local/include -I/usr/pkg/include -I/usr/pkg/include
> -I/usr/local_install/postgre
> sql-7.2.3/include mapwms.c -o mapwms.o
> mapwms.c: In function `msWMSGetCapabilities':
> mapwms.c:705: syntax error before `,'
> gmake: *** [mapwms.o] Error 1
I have committed a fix for this. It looks as if you don't have any of
USE_GD_GIF, USE_GD_PNG, USE_GD_JPEG or USE_GD_WBMP defined for some reason
so there are none of the strings in the #ifdef selected.
However, even with my fix it is clear you aren't going to be able to operate
properly since you will have no formats supported. I would suggest looking
into why none of the USE_GD_XXX constants are defined in your makefile.
When I compile mapwwms.c it looks like this:
gcc -c -g -Wall -DENABLE_STDERR_DEBUG -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ
-DUSE_PROJ_API_H -DUSE_WMS_SVR -DUSE_WMS_LYR -DUSE_TIFF -DUSE_GD_PNG -DUSE_GD_JPEG
-DUSE_GD_WBMP -DUSE_GD_FT -DUSE_OGR -DUSE_GDAL -DUSE_POSTGIS -DUSE_THREAD
-I/usr/include -I/home/warmerda/gdal/port -I/home/warmerda/gdal/core
-I/home/warmerda/gdal/ogr -I/home/warmerda/gdal/ogr/ogrsf_frmts -I/usr/local/include
-I/usr/local/pgsql/include -I/usr/local/include -I/usr/local/include/w3c-libwww
-DHAVE_CONFIG_H mapwms.c -o mapwms.o
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
