[mapserver-users] gmap demo segfault
Caffeinate The World
mochaexpress at yahoo.com
Sun Nov 24 19:36:07 EST 2002
I further narrowed down the cause of the problem. I commented out the line below:
DATA bath_mapserver.tif
and the applet loaded. There seems to be a problem with loading tif files.
LAYER
NAME bathymetry
METADATA
"DESCRIPTION" "Elevation/Bathymetry"
END
TYPE RASTER
STATUS ON
# DATA bath_mapserver.tif
END
Caffeinate The World <mochaexpress at yahoo.com> wrote:
I turned on --enable-debug on the mapsever compile only.. php cgi currently doesn't have it turned on:
Reading symbols from /usr/local/lib/libproj.so...done.
Reading symbols from /usr/pkg/lib/libtiff.so.3...done.
#0 0x16220d06c in drawTIFF (map=0x0, layer=0x1a5, img=0x120456000,
filename=0x0) at mapraster.c:828
---Type <return> to continue, or q <return> to quit---
828 vv=buf[xi+boffset];
(gdb) bt
warning: Hit heuristic-fence-post without finding
warning: enclosing function for address 0x1202fd370
This warning occurs if you are debugging a function without any symbols
(for example, in a stripped executable). In that case, you may wish to
increase the size of the search with the `set heuristic-fence-post' command.
I narrowed the segfault down to this section of gmap75.map:
LAYER
NAME grid
METADATA
"DESCRIPTION" "Grid"
END
TYPE LINE
STATUS OFF
DATA grid
CLASS
NAME "Graticule"
COLOR 0 0 0
END
END # Layer
I still don't know what's causing the segfault. The php.core I have doesn't have debug on to do a backtrace.
mapserver-3.6.3
php-4.2.2 (cgi and apache mod)
NetBSD-Alpha-1.5.2
Apache-1.3.22
I got mapserver going and the default demo working. Then I tried the gmap-3.6 demo and it segmentation fault at the line denoted by "HERE" below :
function GMapDrawMap()
GLOBAL $gpoMap, $gbShowQueryResults;
GLOBAL $gbIsHtmlMode;
GLOBAL $gszCommand, $gszZoomBoxExt;
GLOBAL $gAppletImgFmt, $gImagesFmt;
if ($gbShowQueryResults)
$img = $gpoMap->drawQuery();
else
$img = $gpoMap->draw(); //<--------HERE
Do you Yahoo!?
Yahoo! Mail Plus - Powerful. Affordable. Sign up now
Do you Yahoo!?
Do you Yahoo!?
Do you Yahoo!?
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20021124/f6e7af46/attachment.html
