[mapserver-users] TIFFs no longer displaying
Dylan Keon keon at nacse.org
Sun Nov 24 19:39:57 PST 2002
I'm having a problem where TIFFs will no longer display in my
PHP-MapScript application.  It's especially confusing because I can't
identify what changed on my system (nothing, as far as I can tell).
When I zoom in to the scale where DRGs are displayed, the app crashes
with a 500 Internal Server Error.  This also happens if I put together a
simple mapfile to display a single DRG, along with a simple PHP
interface to just display the image.  The error_log prints a standard
"Premature end of script headers" error.
However, shp2img *is* able to process these mapfiles (including the TIFF
images) and render the output.  tiffinfo has no problem reading the
files, and permissions are not the problem.  This makes me think the
problem is with PHP or something else at that level, but I've recompiled
and tested newer and older versions of PHP along with different versions
of MS, GDAL, and GD, and can't shake this problem.  I've gone so far as
to completely install a separate MapServer environment (MS 3.7 cvs, GDAL
cvs, GD 2.0.7, PROJ 4.4.5, Apache 2.0.43, PHP 4.2.3, libwww 5.4.0) to a
different directory tree, to no avail.  GDAL was compiled with internal
libtiff and libgeotiff support.
I'm hoping someone might have another idea of how to troubleshoot, given
that shp2img works.  I've spent a couple days troubleshooting this and
can't seem to make a dent.
Thanks a lot,
Dylan
More information about the MapServer-users mailing list
