[mapserver-users] Mapserver 3.7 ItemQuery
Name
wesp at gdv.com
Tue Nov 26 17:36:11 EST 2002
IIRC FILTER must be
FILTER "[value]"
On Tue, 26 Nov 2002 20:01:12 +0100, "netGIS Site Manager"
<siteman at netgis.nl> wrote :
> This is a multi-part message in MIME format.
> Hello listmembers!
> I recently joined this list, being a former MapInfo employee, I am
trilled by all the functionallity with OGR! This beats MapXtreme on all
fronts!
> I got a small pilot running at http://netgis.mine.nu/cgi-
bin/mapserv.exe?map=%2Fdata%2Fzeeland.map. All works excellent.
> However, I can't get my itemquery to run.
> currently I have the querable layer like this:
> (Municipalities)
> LAYER
> NAME gemeente
> DATA gemeente_region
> STATUS DEFAULT
> TYPE POLYGON
> # FILTERITEM "MUNNAME"
> # FILTER "value"
> CLASS
> NAME "Gemeente"
> TEMPLATE zeeland_template.htm
> OUTLINECOLOR 0 0 0
> END
> END
> The query I ran against it (when the # signs where out) was:
> http://netgis.mine.nu/cgi-bin/mapserv.exe?map=%2Fdata%
2Fzeeland.map&qlayer=gemeente&mode=itemnquery&item=gemeente&value=GOES
> But I can't get it to work! I even switched to 3.7, but no difference.
Eventually I completely lost track of my actions, an having the FILTER
there without the # even made my entire layer disapear..
> Can anyone tell me the exact syntax for the query? Is it documented
somewhere cause I can't seem to find it...
> I would also like to take part in documenting the features in an
objectmodel, who can tell me where I can join?
> kind regards!
> Milo van der Linden
> www.netgis.nl
> Hogeweg 63, 4328PB Burgh Haamstede
> Zeeland, The Netherlands
> milo at netgis.nl
