[mapserver-users] QuerybyPoint blues
Antti.Roppola at brs.gov.au
Tue Oct 1 20:28:14 EDT 2002
Hi Tom,
I have got queries on polygons and lines working OK (but not points).
Here are the relevant chunks of code.
LAYER
NAME "Roads"
TYPE LINE
STATUS OFF
DATA roads
CLASS
NAME "Roads"
COLOR 255 0 0
TEMPLATE "dummy" # doesn't exist
END
METADATA
"DESCRIPTION" "DCW roads"
## The following are not the same as GMap
"QUERY_FIELDS_ITEM" "FORMATION"
"QUERY_FIELDS_DESC" "Road Formation Code"
END
END
<HTML>
<?php
if($click_x && $mode=="query") { ## Did someone make a query?
## Convert image click location into map coordinates
list($ClickMapX,$ClickMapY)=click2map($click_x,$click_y,$extent,$map)
$pointQuery=ms_newPointObj();
$pointQuery->setXY($ClickMapX,$ClickMapY);
@map->queryByPoint($pointQuery, MS_MULTIPLE, -1);
$img = $map->drawQuery();
QueryResults($pointQuery, $map); ## This function is a hack from the same in Gmap
</HTML>
The QueryResults function is as from GMap (I have not gotten around to
writing my own and it works well enough), though I did add some debug
stuff so I could see what it was doing. In the function, find the line;
"$numResults = $oLayer->getNumResults();
and insert the following line after it:
if ($debug) { printf("Debug: Layer: %s Results: %s<BR>\n", $iLayer, $numResults); }
If you set $debug at the start of the function, this will show you if the
query is actually finding anything for each layer.
Cheers,
Antti
