[mapserver-users] GDAL compilation error
Frank Warmerdam
warmerdam at pobox.com
Mon Oct 28 08:46:06 EST 2002
Sandor Csaba wrote:
> Hi,
> I am trying to install mapserver with gdal support on a Solaris box
> (virtual server, no root privileges). GDAL itself successfully compiles,
> but mapserver configure script gives the following:
> checking if GDAL support requested... yes, user supplied gdal-config
> ./configure: /home/emla/lib/gdal: cannot execute
> What is it trying to execute at this point?
Sandor,
It is trying to execute the path you gave as if it were the gdal-config
script. Is /home/emla/lib/gdal a build directory, or an install directory?
If you installed GDAL you should be able to find a bin/gdal-config script
in the install tree. Use that as the argument to --with-gdal. If you didn't
install GDAL then give /home/emla/lib/gdal/apps/gdal-config as the argument
to the --with-gdal option.
Good luck,
and watch the world go round - Rush | Geospatial Programmer for Rent
