[mapserver-users] Defining Classes/Labels for contours
Puneet Kishor
pkishor at GeoAnalytics.com
Thu Oct 31 09:31:08 EST 2002
No, you don't need to create a new shapefile. As I said, the logic of what
you are doing is correct... there must be something wrong with your
expressions... make sure the field name (Contour) is correct, make it caps
(I think selection might be case-sensitive...) you might have to enclose it
in square brackets/and or quotes... I am talking from the top of my head...
checks the docs or the wiki. There are specific examples.
Your logic is correct. Most likely your expression is wrong.
Puneet.
PS. Please reply to the entire list so others may help|behelped. Thanks.
> -----Original Message-----
> From: Michael Soracco [mailto:Michael.Soracco at noaa.gov]
> Sent: Thursday, October 31, 2002 7:13 AM
> To: Puneet Kishor
> Subject: Re: [mapserver-users] Defining Classes/Labels for contours
> Although there is no mechanism for creating graduated colors,
> should I be able
> to display the "0-5" contour line as RED and the "5-10" as
> GREEN ? The code
> below results in NO contours being displayed, but just Legend
> entries. Is this
> what you mean by no mechanism? I.e. I need to create new
> shapefiles for each
> contour value.
> thanks.
> Puneet Kishor wrote:
> > there is no mechanism for creating graduated colors for a
> feature based on
> > class ranges. What you have done is correct.
> > If you don't want the legends to be created, just take out
> the NAME line
> > from within the CLASS definitions.
> > Hth.
> > Pk/
> > Sent: Wednesday, October 30, 2002 2:17 PM
> > To: mapserver
> > Subject: [mapserver-users] Defining Classes/Labels for contours
> > I've checked the archives and didn't see anything on what I
> need to do.
> > It's probably straightforward, but I haven't been able to
> figure it out...
> > I have a Polyline shapefile where each polyline has a
> classified value (i.e.
> > Contour 1,2,3,4,5,6,7,8,9,10). I've tried the following to draw the
> > contours in different colors but have only succeeded in
> creating a Legend
> > Class for each level. Is it possible to have graduated
> colors for the lines
> > within the same Layer Object?
> > LAYER
> > NAME BATHY
> > TYPE LINE
> > STATUS OFF
> > DATA bathy
> > CLASSITEM "Contour"
> > MAXSCALE 500000
> > CLASS
> > NAME "0 - 5"
> > EXPRESSION "(Contour >= 0 AND Contour <=5)"
> > COLOR 200 0 0
> > END
> > CLASS
> > NAME "5 - 10"
> > EXPRESSION "(Contour > 5 AND Contour <=10)"
> > COLOR 0 200 0
> > END
> > END
> > Thanks in advance for the help.
> > Michael Soracco
> > SES, Inc. for NOAA/NESDIS
> > at NOAA Science Center (WWB)
> > 5200 Auth Road, Room 607
> > Camp Springs, MD 20746
> > Voice: 301.763.8142 x117
> > FAX: 301.763.8131
> Michael Soracco
> FAX: 301.763.8131
