[mapserver-users] Defining Classes/Labels for contours
Michael Soracco
Michael.Soracco at noaa.gov
Thu Oct 31 11:25:21 EST 2002
Yup, it was the syntax. For the archive's sake, it should look like:
EXPRESSION ( ( [CONTOUR] >= 0 ) AND ( [CONTOUR] <5) )
Thanks again.
-m
Puneet Kishor wrote:
> No, you don't need to create a new shapefile. As I said, the logic of what
> you are doing is correct... there must be something wrong with your
> expressions... make sure the field name (Contour) is correct, make it caps
> (I think selection might be case-sensitive...) you might have to enclose it
> in square brackets/and or quotes... I am talking from the top of my head...
> checks the docs or the wiki. There are specific examples.
> Your logic is correct. Most likely your expression is wrong.
> Puneet.
> PS. Please reply to the entire list so others may help|behelped. Thanks.
> > -----Original Message-----
> > From: Michael Soracco [mailto:Michael.Soracco at noaa.gov]
> > Sent: Thursday, October 31, 2002 7:13 AM
> > To: Puneet Kishor
> > Subject: Re: [mapserver-users] Defining Classes/Labels for contours
> > Although there is no mechanism for creating graduated colors,
> > should I be able
> > to display the "0-5" contour line as RED and the "5-10" as
> > GREEN ? The code
> > below results in NO contours being displayed, but just Legend
> > entries. Is this
> > what you mean by no mechanism? I.e. I need to create new
> > shapefiles for each
> > contour value.
> > thanks.
> > > there is no mechanism for creating graduated colors for a
> > feature based on
> > > class ranges. What you have done is correct.
> > > If you don't want the legends to be created, just take out
> > the NAME line
> > > from within the CLASS definitions.
> > > Hth.
> > > Pk/
> > > Sent: Wednesday, October 30, 2002 2:17 PM
> > > To: mapserver
> > > Subject: [mapserver-users] Defining Classes/Labels for contours
> > > I've checked the archives and didn't see anything on what I
> > need to do.
> > > It's probably straightforward, but I haven't been able to
> > figure it out...
> > > I have a Polyline shapefile where each polyline has a
> > classified value (i.e.
> > > Contour 1,2,3,4,5,6,7,8,9,10). I've tried the following to draw the
> > > contours in different colors but have only succeeded in
> > creating a Legend
> > > Class for each level. Is it possible to have graduated
> > colors for the lines
> > > within the same Layer Object?
> > > LAYER
> > > NAME BATHY
> > > TYPE LINE
> > > STATUS OFF
> > > DATA bathy
> > > CLASSITEM "Contour"
> > > MAXSCALE 500000
> > > CLASS
> > > NAME "0 - 5"
> > > EXPRESSION "(Contour >= 0 AND Contour <=5)"
> > > COLOR 200 0 0
> > > END
> > > CLASS
> > > NAME "5 - 10"
> > > EXPRESSION "(Contour > 5 AND Contour <=10)"
> > > COLOR 0 200 0
> > > END
> > > END
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20021031/b3c5ce55/attachment.html
