[mapserver-users] external links in a map
Richard Greenwood
Rich at GreenwoodMap.com
Wed Sep 4 12:00:25 EDT 2002
At 10:37 AM 9/4/2002 +0100, you wrote:
>Hi all,
>Is there a way to include URL's / links into a map?
>For example: the user clicks on an object, symbol or label and the click
>triggers the link.
>Thanks for all suggestions,
>Stefan
Put the URL in your TEMPLATE definition. Here's something I posted a year
or so ago:
A TEMPLATE can be either a File or a URL. MapServer examines a template
definition, decides whether you have specified a File or a URL, and
responds accordingly. For example;
"Display_Results.html"
looks like a file and so will be processed as a file, but
"http://www.some_domain.com/Index.html"
looks like a URL and so will be processed as a URL, which is quite a
bit different than how a File is processed.
If MapServer decides that it has a file template, it goes through the file
and replaces stuff within [] with appropriate data. If the template is a
URL, however, MapServer redirects to that URL. The URL might be on the same
server, or another server. Although MapServer can not process the file
pointed to by a URL, it does process the URL string itself. For example:
http://www.tetonwyo.org/clerk/query/default.asp?pidn=[PIDN]
MapServer will replace [PIDN] with an appropriate value before redirecting
to the new location. Note also that you can go to an Active Server Page, or
other not-purely HTML type location. (To me, this is really sweet, because
it allows you to easily mix CGI MapServer with other web technologies.)
Okay, so you read this far and I still haven't told you anything that you
didn't already know, but here's what had me flailing. A template can only
reference a URL in a SINGLE query mode. So if you are in a MULTIPLE query
mode, e.g. nquery, MapServer only attempts to processes the template as a
file. Not a good thing if you specified a URL, but still entirely logical.
A URL is intrinsically a single thing, and you can't simultaneously
redirect a browser to multiple locations. In other words, MapServer assumes
that if your query could potentially return more than one result, that you
would have specified a File for the template, not a URL.
Richard W. Greenwood, PLS
Greenwood Mapping, Inc.
(307) 733-0203
http://www.GreenwoodMap.com
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020904/1d0a4af1/attachment.html
