[mapserver-users] problems when requesting for feature info in gml format
Hao Ding
hdi12 at it.canterbury.ac.nz
Sat Sep 7 21:50:28 EDT 2002
Hello,
I got some problems when request GetFeatureInfo to the MapServer for GML
response.
I used itasca demo data as the sample dataset. When requesting the lake
feature using default INFO_FORMAT with the URL below, I can get the results.
http://localhost:8080/cgi-bin/mapserv?VERSION=1.1.0&REQUEST=GetFeatureInfo&SRS=EPSG:4326&BBOX=388014.0,5200400.0,500802.0,5313160.0&WIDTH=800&HEIGHT=400&FORMAT=image/gif&LAYERS=lakespy2&STYLES=default&TRANSPARENT=TRUE&QUERY_LAYERS=lakespy2&X=274&Y=192
GetFeatureInfo results:
Layer 'lakespy2'
Feature 23043:
gid = '844'
area = '407475.09544'
perimeter = '2302.07951'
usclass = '421'
dowlknum = '31081700'
dow_verif = '0'
lake_name = ''
lake_class = '0'
elevation = '1296'
acres = '100.687'
perfeet = '7553.123'
If I add the parameter INFO_FORMAT=application/vnd.ogc.gml, the body of
the gml file I got was empty
<?xml version="1.0" encoding="ISO-8859-1"?>
<msGMLOutput
xmlns:gml="http://www.opengis.net/gml"
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:xsi="http://www.w3.org/2000/10/XMLSchema-instance">
</msGMLOutput>
I just wonder if I need to do something in the mapfile for gml export? I
also don't know what the object "dump" in the mapfile is used for.(I
saw the sentence "DUMP true" in some Layers).
Thanks very much for any help!!!
Hao
