[mapserver-users] problems when requesting for feature info in gml format
Hao Ding
hdi12 at it.canterbury.ac.nz
Mon Sep 9 20:47:43 EDT 2002
Thanks, Steve. I've tried set DUMP to TRUE, but unfortunately I got
"Internal Server Error". If I comment the sentence "DUMP true", I can
get a gml response but no content as I said last time. Do I have to do
some setting on the apache http server?
Thanks,
Hao
Steve Lime wrote:
> You must set DUMP to TRUE for any layer you want GML output for. That's
> there as a basic security feature.
> Steve
> Stephen Lime
> Data & Applications Manager
> Minnesota DNR
> 500 Lafayette Road
> St. Paul, MN 55155
> 651-297-2937
>>>>Hao Ding <hdi12 at it.canterbury.ac.nz> 09/07/02 08:50PM >>>
> Hello,
> I got some problems when request GetFeatureInfo to the MapServer for
> GML
> response.
> I used itasca demo data as the sample dataset. When requesting the lake
> feature using default INFO_FORMAT with the URL below, I can get the
> results.
> http://localhost:8080/cgi-bin/mapserv?VERSION=1.1.0&REQUEST=GetFeatureInfo&SRS=EPSG:4326&BBOX=388014.0,5200400.0,500802.0,5313160.0&WIDTH=800&HEIGHT=400&FORMAT=image/gif&LAYERS=lakespy2&STYLES=default&TRANSPARENT=TRUE&QUERY_LAYERS=lakespy2&X=274&Y=192
> GetFeatureInfo results:
> Layer 'lakespy2'
> Feature 23043:
> gid = '844'
> area = '407475.09544'
> perimeter = '2302.07951'
> usclass = '421'
> dowlknum = '31081700'
> dow_verif = '0'
> lake_name = ''
> lake_class = '0'
> elevation = '1296'
> acres = '100.687'
> perfeet = '7553.123'
> If I add the parameter INFO_FORMAT=application/vnd.ogc.gml, the body of
> the gml file I got was empty
> <?xml version="1.0" encoding="ISO-8859-1"?>
> <msGMLOutput
> xmlns:gml="http://www.opengis.net/gml"
> xmlns:xlink="http://www.w3.org/1999/xlink"
> xmlns:xsi="http://www.w3.org/2000/10/XMLSchema-instance">
> </msGMLOutput>
> I just wonder if I need to do something in the mapfile for gml export?
> I
> also don't know what the object "dump" in the mapfile is used for.(I
> saw the sentence "DUMP true" in some Layers).
> Thanks very much for any help!!!
> Hao
