[mapserver-users] Mapserver Performance Statistics
woodbri at swoodbridge.com
Mon Sep 9 08:21:43 EDT 2002
Pradeep,
Much of the testing results and stats you are asking for will be
highly related to the specific hardware setup the was tested and
probably can not be translated to a different hardware configuration.
I did some stress testing a while back on a mapserver configuration
using something called siege. The most recent released version
of siege is available by anonymous ftp from ftp.armstrong.com in
the directory pub/siege.
The thinks that determine mapservers ability to handle requests are
the same things for any other hardware, like number of cpus, amount
of memory, speed of disk, load balancing across multiple systems.
What your disk cache hit ratio is.
Things like its a CGI app don't enter the picture because that is
what mapserver IS, sure if it could be a module it might run a little
faster, but it isn't right now.
But probably the BIGGEST performance problem I have seen repeatedly
with mapserver is that people that have not work extensively with do
not know how to optimize the map file, tileindexes, spatial indexes,
etc to make mapserver fast.
I was able to get the system I ran siege on to render consistently at
8-10 secs for out of cache queries and 2-3 secs for cache hit
queries. Is this good? Well that was down from 45+ sec per render
before I started working with is. But is this good? It was as good as
the piece of hardware could do, but it was not a server class
machine, it was a desktop system with very slow IDE drives, no raid,
single cpu, 1 GHz processor, 1 GB of memory, but I was able to get
similar performance from my 450 Mhz, 128 MB box because it was
equally I/O bound.
If you want to collect stats on your CGI hits, write a script called
something like php2 and place in it:
time -o /tmp/time-stats.log --append /path/to/php $*
and place it in your cgi-bin directory and have your webserver
execute it instead of php, or do something similar for mapserv and
then run siege and you can compare the siege stats along with the cpu
and i/o performance numbers.
Hope this helps,
-Steve
On 9 Sep 2002 at 17:06, Pradeep wrote:
> Hello,
> We are evaluating the performance of Mapserver to go ahead
> with plans of developing a product based on the MapServer core, and we
> are looking for statistics on the performance issues listed such as
> The No of requests per second, the success rate, the HTTP errors, the
> amount of processor overhead, the memory bloat...etc etc..
> Can some one be kind enough to shed more light on any previous work
> already done on any performance issues of MapServer.... I would be
> glad to see figures related to performance, and a comparitive study of
> MapServer vis-a-vis any other similar product/tool available in the
> market.
> PS: One moot question I would like to ask the folks all around is
> "What are the pros and cons of MapServer being a CGI Exe, is it an
> Ideal choice for a Web Application, as we know generally that all CGI
> apps have an inherent issue of getting loaded in to the memory for
> each request".
> Regards,
> Pradeep.
