[Mapserver-users] Proj problems
Vincent Schut
schut at sarvision.com
Fri Aug 1 04:29:24 EDT 2003
Gerry,
Additionally, indeed as Randy already pointed out, your imageurl looks faulty.
It should be what you have to type in your browser to get in the tmp
directory where mapserver puts its output images, which is (hopefully) not
/var/www/etc. but something like tmp/ or mesonet/tmp/, depending on how you
defined (aliased) that directory in your httpd.conf presuming you are using
apache.
cheers,
Vincent.
On Thursday 31 July 2003 23:28, Gerry Creager wrote:
> OK, I'm pretty much at my wits' end. I've tried looking at this on a
> time-available basis, and I'm just not getting it.
> A mapserv -v yields the following:
> [root at mesonet cgi-bin]# ./mapserv -v
> MapServer version 3.7 (development) OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=GD2_RGB INPUT=OGR
> INPUT=GDAL INPUT=SHAPEFILE
> PROJ support is there, so it should allow me to specify a projection
> section, either with the EPSG shortcut or the long way, with everything
> specified. I've tried that and what I end up with is essentially a
> blank screen...
> If someone's got suggestions, great. The mapfile is attached. I'll
> keep looking at it, but it's looking like my hair's on fire and I can't
> get it put out...
> Thanks in advance,
> Gerry
______________________________________
Vincent Schut
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
