[Mapserver-users] since the update to V4.0: "funny" maps :-(
Rainer Spittel
rasp at tzi.de
Mon Aug 4 03:20:58 EDT 2003
I have problems with the new version of the mapserver. Properly
this error is not a MapServer error, more a configuration problem:
1. Since updating to MapServer 3.7/4.0beta or 4.0(final) the images
aren't displayed correct. For example: A map with four layers. Each
layer have six class definition.
The mapserver will display each (single) layer correct. But when I
enable two or three layers, the mapserver will mix-up the appearance of
the classes. Even some features won't be displayed.
For example: each layer displays the same region of a district, the
color is defined in the class objects and the outline-colors of all
layers are BLACK. When I enable three layers, the outline of the
district appears red.
2. Another graphical error occurs when I use the ROSA applet for java
support. When the user drags a bounding box, each black-bounding box
will be drawn, but don't disappear when the mouse is moved.
3. Lines, which have a size larger than one, are always black.
That's why, I can't update my system, but I want, because the
features of the NEW mapserver are very, very interesting.
My system configurations are:
RedHeat 9.0
ming-0.2a
curl-7.10.5
gd-2.0.15
gdal-1.1.8
php-4.3.2
proj-4.4.7
and:
Suse 8.0
apache_1.3.27
jasper-1.700.2.uuid
curl-7.10.5
gd-2.0.15
gdal-1.1.9
php-4.2.3
proj-4.4.7
I need HELP !!! ;-)
Thx,
Rainer
