[Mapserver-users] Red Hat LInux Mapserver/Mapscript compilation
Gerry Creager N5JXS
gerry.creager at tamu.edu
Tue Aug 12 23:26:37 EDT 2003
On RedHat, we've ripped out Apache and PHP, as they came from RedHat...
and PostGres, as well, and installed from tarball. Doing this, we've
seen no problems that weren't related to fumbling the keyboard. Before
we decided on this approach, we had all sorts of problems accessing PHP
reliably and using Postgres as a standard DB call.
HTH,
Gerry
Daniel Morissette wrote:
> Removing or changing MapServer's configure options won't help with this.
> The root of the problem is really that the PHP configure
> --with-regex=system didn't work. Usually this is caused by using the
> --with-apxs switch in configuring PHP but you don't appear to be using
> it. There must be another PHP configure option that you use and that
> conflicts with the --with-regex=system but I have no clue which one it
> would be. I would suggest checking your PHP configure output in case
> there is a message about this.
> To tell if your PHP did properly select the system regex, you can look
> at php-4.3.2/main/php_config.h. If you find a line saying '#define
> REGEX 1' then it's using the builtin regex (no good). If you don't find
> that line then it's using the system regex and you're fine.
> Daniel
> Alexander Shostko wrote:
>> Thanks for review
>> I tried to compile the mapserver using 4.0 with recommended
>> features, in some details:
>> ming, curl, curl-dev and other packages have been installed,
>> After which I reinstalled gdal.1.18 by
>> ./cble-force-cgi-redirect \
>> --enable-discard-path \
>> --with-config-file-path=/etc/httpd/ \
>> --with-gd=/usr/local \
>> --with-jpeg-dir \
>> --with-png-dir \
>> --with-zlib-dir \
>> --with-freetype-dir \
>> --without-ttf \
>> --with-pdflib \
>> --with-mysql \
>> --with-regex=system \
>> --enable-dbase \
>> --enable-dbx \
>> --enable-versioning
>> make make ogr-all
>> make install
>> 4. Now trying to install php in the same fashion
>> rm -f config.cashe
>> ./configure \
>> --enable-force-cgi-redirect \
>> --with-jpeg-dir \
>> --with-png-dir \
>> --with-zlib-dir \
>> --without-ttf \
>> --with-pdflib \
>> --with-mysql \
>> --enable-dbase \
>> --enable-dbx \
>> --enable-versioning
>> make cp sapi/cgi/php /var/www/cgi-bin
>> cp php.ini-dist /etc/httpd/php.ini
>> proj, libpng, libtiff, zlib ... and other libraries are already
>> there.
>> 6. Installing mapserver
>> rm -r config.cache
>> ./configure \
>> --without-tiff \
>> --without-eepl \
>> --without-jpeg \
>> --with-threads \
>> --with-proj \
>> --with-gdal=/usr/local/bin \
>> --with-php=../php-4.3.2 \
>> --with-freetype=/usr/bin \
>> --with-pdf \
>> --with-ogr \
>> --with-gdal \
>> --with-ming \
>> --with-wmsclient \
>> --with-wfs \
>> --with-wfs-client
>> After which ./configure gets the message:
>> !!! The current version of PHP MapScript has some problems with !!!
>> !!! PHP4's bundled regex. Until we figure the solution to the !!!
>> !!! problem, the workaround is to compile PHP4 with the system
>> regex !!!
>> !!! Please re-configure and re-compile PHP4 with
>> --with-regex=system !!!
>> !!! and then re-configure and re-compile MapServer. !!!
>> However php is compiled --with-regex=system
>> Plan to reduce the number of features in mapserver and try
>> again
>> Thanks for tips
>> Regards
>> Alex
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Gerry Creager -- gerry.creager at tamu.edu
Texas Mesonet -- AATLT, Texas A&M University
Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.847.8578
Page: 979.228.0173
Office: 903A Eller Bldg, TAMU, College Station, TX 77843
