[Mapserver-users] PostGIS Query Results
Damian Schroder
map_surfer at yahoo.com
Mon Aug 18 17:17:42 EDT 2003
Below is my error message from preforming a query with
PostGIS data layers. Mapserver/Rosa is working great
in that all my vector based data is being displayed. I
have other PHP application accessing Postgresql easy
enough. It is something with Rosa/PHP/Mapscript, but
not sure where.
TIA
Internal Server Error
The server encountered an internal error or
misconfiguration and was unable to complete your
request.
Please contact the server administrator,
webmaster at localhost and inform them of the time the
error occurred, and anything you might have done that
may have caused the error.
More information about this error may be available in
the server error log.
Apache/1.3.27 Server at localhost Port 80
--- "Pericles S. Nacionales" <nacional at cbs.umn.edu>
wrote:
> And what might the message be? Without knowing
> where to start, I'll
> shoot blindly and claim that your error is due to
> missing PostGIS client
> library. :) If not, then I would say you forgot to
> update all your
> libraries and application files. I tell you this
> because they are the
> two most common problems that people seem to run
> into these days.
> But really, what does the error message say? Don't
> forget to check
> Apache's error log as well.
> Good luck!
> Perry N.
> On Mon, 2003-08-18 at 14:49, Damian Schroder wrote:
> > I originally built a site (PHP/MapScript)
> accessing
> > shapefiles. Using the ROSA applet the query worked
> > fine. Now that I switched over to PostGIS it
> doesn't
> > work and returns a server error(apache style).
> Does
> > anyone have any ideas why this would happen? (RH9
> > Mapserver 4.0b)
> > TIA
> > __________________________________
> > Do you Yahoo!?
> > Yahoo! SiteBuilder - Free, easy-to-use web site
> design software
> > http://sitebuilder.yahoo.com
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> Pericles S. Nacionales <nacional at cbs.umn.edu>
> University of Minnesota
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
