[Mapserver-users] Optimising PostGIS relates/subselects/views
Antti.Roppola at brs.gov.au
Mon Feb 3 19:41:42 EST 2003
Thanks, the indexing reduced the map render time from 82 seconds
to 9 seconds.
Cheers,
Antti
-----Original Message-----
From: David Blasby [mailto:dblasby at refractions.net]
Sent: Tuesday, 4 February 2003 11:41 AM
To: Antti.Roppola at brs.gov.au
Cc: mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] Optimising PostGIS
> DATA "the_geom FROM
> (SELECT mylayer.oid AS oid,
> mylayer.the_geom AS the_geom,
> mytable.value AS value
> FROM mylayer, mytable
> WHERE mylayer.lut=mytable.lut)
> AS mylayer
> USING oid
> USING srid=-1"
> CLASSITEM "value"
Ensure you have an index on mylayer.lut and mytable.lut:
CREATE INDEX mytable_lut_idx ON mytable (lut);
CREATE INDEX mylayer_lut_idx ON mylayer (lut);
You might want to change "...AS mylayer..." to "..AS foo..." so you're not
equivocating "mylayer".
If this doesnt speed things up, you'll have to use the new
index-selectivity support in the CVS version of PostGIS. See the postgis
mailing list for more details.
dave
