[Mapserver-users] RE: problem with boundaries
    ryanne cruz
    ryanne.cruz at up.edu.ph
    Mon Feb  3 20:59:53 PST 2003
hi list.
i have included in this email a sample of the map that we were able to
display. as you can see, the data is not contained within the map. some are in
the fringes. i used the distance function to get these data. an example is:
select the_geom from table1 where distance(table1.the_geom,table2.the_geom)=0;
this was the closest thing i could get, in terms of the map bounding the data.
any ideas on how i could make it better?
thanks!
More information about the MapServer-users
