[Mapserver-users] Projection woes, Revisited.
Hankley, Chip
Chip.Hankley at GASAI.Com
Tue Feb 4 17:05:45 EST 2003
That'd be helpful... if you e-mail it, please ZIP it, or it won't make it
through our firewall.
Please confirm this though... when building, you:
a) compiled the associated libraries (GD, PNG, etc.)
b) compiled PROJ4, presumably pointing to the data shift grids
c) compiled MapServer.
I don't know who compiles the Win32 binaries on the MS site. It'd be
interesting to know if they do whatever needs to be done in "b" to make
datum shifts work.
Thanks a lot Ed!
Chip
> -----Original Message-----
> From: Ed McNierney [mailto:ed at topozone.com]
> Sent: Tuesday, February 04, 2003 3:33 PM
> To: Hankley, Chip; MapServer List (E-mail)
> Subject: RE: [Mapserver-users] Projection woes, Revisited.
> Chip -
> OK - I can run your final example and get the right answer.
> That is, I get a green box with a red border neatly placed around it.
> Now, I can say very little about your 3.6.3 build, since I
> don't know the details of how it was built. I can provide
> you with the 3.7 build I am using for testing, which would at
> least let you determine whether it's a PROJ data file setup
> issue or a MapServer code issue.
> - Ed
> From: Hankley, Chip [mailto:Chip.Hankley at GASAI.Com]
> Sent: Tuesday, February 04, 2003 4:11 PM
> To: Ed McNierney; MapServer List (E-mail)
> It's in there. It's called box_sps83m.*
> Thanks again...
> Chip
> > Sent: Tuesday, February 04, 2003 2:02 PM
> > Chip -
> > Thanks - one more request - could you update the ZIP file
> > with the new shapefile?
> > - Ed
> > Sent: Tuesday, February 04, 2003 2:52 PM
> > OK,
> > I've added another demo onto the page:
> > http://207.250.243.23/projtest/projtest.html
> > This last one has only the two 'boxes', and the output
> > projection is WI
> > State Plane South, NAD83, meters (epsg:32154). Note that this
> > necessitated
> > me creating a new data set, since my other SPS83 box was
> > FEET. The epsg code
> > assumes the data is meters.
> > I also changed the NAD27 box to be transparent with a red
> > outline for the
> > last two examples (just to show for sure that it is not
> reprojecting).
> > Also, just in case anyone was wondering... those are in-line
> > images being
> > created on the fly using MS (look at the source) so.. you are
> > seeing the
> > real deal - i.e. I'm not making this up ;)
> > Thanks for the interest and help!
> > Chip
> > > Sent: Tuesday, February 04, 2003 1:07 PM
> > > Chip -
> > > Thanks for posting all the data and samples. I think it
> > > might be helpful to simplify things a bit.
> > > Here's what I see. You have two boxes, of the same extents,
> > > one in Wisconsin South NAD27 Feet, the other in Wisconsin
> > > South NAD83 Feet (both LCC projections). Let's ignore
> > > everything else and try to get those two to overlap.
> > > First, you might want to use the EPSG codes for these
> > > projections. They're more obtuse, but they protect against
> > > typos when spelling out all the projection parameters.
> > > For Wisconsin State Plane South NAD27, the code is 32054, and
> > > for NAD83 it's 32154. So each of your projection blocks
> can become:
> > > # NAD27
> > > PROJECTION
> > > "init=epsg:32054"
> > > END
> > > # NAD83
> > > PROJECTION
> > > "init=epsg:32154"
> > > END
> > > This is similar to your last example. In looking at your
> > > last example, however, one wonders whether the NAD83 box is
> > > right there UNDERNEATH the red NAD27 box - if it were
> > > projecting properly, how could you tell?
> > > Can you set up another example that does the following:
> > > 1. Uses the EPSG codes for projections
> > > 2. Defines the output projection to be Wisconsin State Plane
> > > South NAD83
> > > 3. Defines only two input layers
> > > 4. Makes the OUTLINECOLOR for the NAD27 box be "255 0 0"
> > > (red) and removes the COLOR statement, so it's hollow?
> > > Then let us take a look. Thanks!
> > > - Ed
> > > Sent: Tuesday, February 04, 2003 1:18 PM
> > > Ed (and everyone) -
> > > OK... showing my ignorance here. I ALWAYS use pre-compiled
> > > binaries (I'm
> > > trying to overcome this personal defect...). Anyway, I'm only
> > > beginning to
> > > understand the compilation sequence, and how all the parts
> > > fits together...
> > > so, patience please!
> > > When I download the binaries from the Mapserver site, the
> > > only PROJ related
> > > file that comes with the distribution is the epsg file. I
> > have this in
> > > C:\PROJ\NAD.
> > > I did download the datum shift files (from remotesensing.org)
> > > and simply put
> > > them in the NAD subdirectory, but this doesn't seem to make
> > > any difference
> > > (not suprisingly). I'm assuming that when you say that I
> > > "need to have these
> > > datum shift files set up and PROJ pointed to them in order to
> > > do the shift"
> > > that this is an operation that would occur when compiling the
> > > PROJ4 library
> > > prior to compiling MapServer? Have I got that sequence right?
> > > If this is right, why don't the pre-compiled binaries that
> > > exist already do
> > > this (just curious)? Seems like datum shifts would be a
> > fairly common
> > > task...
> > > Chip
> > > > Sent: Tuesday, February 04, 2003 11:36 AM
> > > > Chip -
> > > > The PROJ4 FAQ refers to the work you need to do to have the
> > > > NAD datum shift files built - the code doesn't change. Do
> > > > you have your PROJ installation in C:\PROJ? Whereever it is,
> > > > look in that directory for a NAD subdirectory and files named
> > > > CONUS, NAD27, NAD83, ALASKA, etc. (no file extensions). You
> > > > need to have these datum shift files set up and PROJ pointed
> > > > to them in order to do the shift.
> > > > - Ed
> > > > Ed McNierney
> > > > President and Chief Mapmaker
> > > > TopoZone.com / Maps a la carte, Inc.
> > > > 73 Princeton Street, Suite 305
> > > > North Chelmsford, MA 01863
> > > > ed at topozone.com
> > > > (978) 251-4242
> > > > From: Hankley, Chip [mailto:Chip.Hankley at gasai.com]
> > > > Sent: Tuesday, February 04, 2003 12:17 PM
> > > > To: MapServer List (E-mail)
> > > > Subject: [Mapserver-users] Projection woes, Revisited.
> > > > OK, I'm still unable to do a datum shift between NAD27
> and NAD83.
> > > > I've tried to strip out all of the non-essentials and come
> > > up with an
> > > > example. You can view it on-line at:
> > > > Basically, I can reproject data FINE when it's in the same
> > > > datum. It's when
> > > > I try to do a datum shift that things don't work. I'm using
> > > one of the
> > > > pre-compiled binaries from the MS site. Here's my version info:
> > > > MapServer version 3.6.3 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> > > > SUPPORTS=PROJ
> > > > SUPPORTS=TTF SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> > > > INPUT=TIFF INPUT=EPPL7
> > > > INPUT=JPEG INPUT=OGR INPUT=SHAPEFILE
> > > > Could the problem be with the way PROJ4 was compiled into
> > > > this binary? The
> > > > PROJ4 FAQ has some specific instructions for building PROJ4
> > > > to support datum
> > > > shifts... (see http://www.remotesensing.org/proj/faq.html). I
> > > > don't know how
> > > > to check this on the binary...
> > > > TIA!
> > > > Chip
> > > > _______________________________________________
> > > > Mapserver-users mailing list
> > > > Mapserver-users at lists.gis.umn.edu
> > > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
