[Mapserver-users] Re: [Bug 270] 24-bit image processing crash
Brent Fraser bfraser at geoanalytic.com
Fri Feb 7 07:14:11 PST 2003
Steve,
  I think this can be solved with a note in the documentation.  I had
discovered the issue while experimenting with HTML Legends with layers that
referenced 24-bit raster data.
    The rule is: "Adding a CLASS section to a raster LAYER will cause the
raster to be classified."
Seems obvious to me now!
I doubt if anyone will want to classify a 24-bit raster using MapServer (as
Frank pointed out, the processing time could be significant).
Thanks!
Brent
----- Original Message -----
To: <bfraser at geoanalytic.com>
Sent: Thursday, February 06, 2003 6:57 PM
Subject: [Bug 270] 24-bit image processing crash
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=270
> warmerdam at pobox.com changed:
>            What    |Removed                     |Added
>          AssignedTo|warmerdam at pobox.com
|steve.lime at dnr.state.mn.us
> ------- Additional Comments From warmerdam at pobox.com  2003-02-06
19:57 -------
> Steve,
> Brent mentions that he was using a CLASS with an RGB layer with
> the intention of producing a legend entry, but not really wanting to
> affect the way the layer looks.  Currently if there are classes the
> raster code treats a layer quite differently.
> Do you have any thoughts on how Brent could generate a legend entry in
another
> way, or if there is some mechanism by which I should avoid treating the
layer
> as classified?
> ------- You are receiving this mail because: -------
> You are on the CC list for the bug, or are watching someone who is.
More information about the MapServer-users mailing list
