[Mapserver-users] WMS client layer and TerraServer
Brian Fischer
bfischer at mpls.houstoneng.com
Fri Feb 14 09:40:29 EST 2003
This is a multi-part message in MIME format.
------_=_NextPart_001_01C2D437.052F0175
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
I would like to add the TerraServer WMS as a layer in an application,
but I am not sure what version and compiled support for MapServer I need
to make this work. I am currently using 3.6.3 and I know it does not
work with that version. Will I need to upgrade to 3.7 or will 3.6.4
work?
=20
Is anyone else successfully using the TerraServer as a WMS layer? I
know there have been past post that said it works with 3.7, but unless
you are using GD2.x the image does not look the best. Are there any
other free sources or very cheap sources for USGS DOQ's and DRG's as a
WMS Service?
=20
Thanks,
Brian
Content-Type: text/html;
charset="us-ascii"
<html>
<head>
<meta http-equiv=3DContent-Type content=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DGenerator content=3D"Microsoft Word 10 (filtered)">
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{margin:0in;
margin-bottom:.0001pt;
font-size:12.0pt;
font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
p.MsoAutoSig, li.MsoAutoSig, div.MsoAutoSig
{margin:0in;
font-size:12.0pt;
span.EmailStyle17
{font-family:Arial;
color:windowtext;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;}
div.Section1
{page:Section1;}
</style>
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'>I would like to add the TerraServer WMS as a layer in =
an
application, but I am not sure what version and compiled support for =
I need to make this work. I am currently using 3.6.3 and I know it =
does
not work with that version. Will I need to upgrade to 3.7 or will =
3.6.4
work?</span></font></p>
font-family:Arial'> </span></font></p>
font-family:Arial'>Is anyone else successfully using the TerraServer as =
a WMS
layer? I know there have been past post that said it works with =
3.7, but
unless you are using GD2.x the image does not look the best. Are =
there
any other free sources or very cheap sources for USGS DOQ’s and =
DRG’s
as a WMS Service?</span></font></p>
font-family:Arial'>Thanks,</span></font></p>
font-family:Arial'>Brian</span></font></p>
</div>
</body>
</html>
=00
------_=_NextPart_001_01C2D437.052F0175--
