[Mapserver-users] WMS client layer and TerraServer
Ed McNierney
ed at topozone.com
Fri Feb 14 11:17:44 EST 2003
This is a multi-part message in MIME format.
------_=_NextPart_001_01C2D444.9AF7C6D0
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Brian -
=20
If you're going to be using a WMS client, I would recommend moving up to =
3.7. The 3.6x versions used libwww for HTTP transfers, and 3.7 uses the =
much simpler libcurl to do that. Since WMS support is clearly an =
active, ongoing development area, it's worth it to make the change now =
and avoid the libwww process.
=20
We have used TerraServer's WMS interface. I'm not sure exactly what =
problem you've having with the images - certainly, if you're adding =
other data on top and need more palette space, moving up to 3.7/GD 2.x =
will be a big improvement.
=20
We offer USGS DOQQs and DRGs as OGC WMS services for commercial =
customers. They are not free. Given the considerable expense involved =
in providing this data online, we think they're pretty affordably =
priced, but they're not "cheap". The DRGs are much less expensive than =
the DOQQs. Unlike TerraServer, the data we have available as WMS layers =
is full-resolution GeoTIFF data as it is delivered from the USGS. The =
TerraServer imagery is converted to JPEGs to save space, and that can =
make a noticeable difference.
=20
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242=20
-----Original Message-----
From: Brian Fischer [mailto:bfischer at mpls.houstoneng.com]
Sent: Friday, February 14, 2003 9:40 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] WMS client layer and TerraServer
I would like to add the TerraServer WMS as a layer in an application, =
but I am not sure what version and compiled support for MapServer I need =
to make this work. I am currently using 3.6.3 and I know it does not =
work with that version. Will I need to upgrade to 3.7 or will 3.6.4 =
work?
=20
Is anyone else successfully using the TerraServer as a WMS layer? I =
know there have been past post that said it works with 3.7, but unless =
you are using GD2.x the image does not look the best. Are there any =
other free sources or very cheap sources for USGS DOQ's and DRG's as a =
WMS Service?
=20
Thanks,
Brian
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1141" name=3DGENERATOR>
<STYLE>@page Section1 {size: 8.5in 11.0in; margin: 1.0in 1.25in 1.0in =
1.25in; }
P.MsoNormal {
FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman"
LI.MsoNormal {
DIV.MsoNormal {
A:link {
COLOR: blue; TEXT-DECORATION: underline
SPAN.MsoHyperlink {
A:visited {
COLOR: purple; TEXT-DECORATION: underline
SPAN.MsoHyperlinkFollowed {
P.MsoAutoSig {
LI.MsoAutoSig {
DIV.MsoAutoSig {
SPAN.EmailStyle17 {
COLOR: windowtext; FONT-FAMILY: Arial
DIV.Section1 {
page: Section1
</STYLE>
</HEAD>
<BODY lang=3DEN-US vLink=3Dpurple link=3Dblue>
<DIV><SPAN class=3D875200416-14022003><FONT face=3DArial color=3D#0000ff =
size=3D2>Brian=20
-</FONT></SPAN></DIV>
size=3D2></FONT></SPAN> </DIV>
size=3D2>If=20
3.7. =20
The 3.6x versions used libwww for HTTP transfers, and 3.7 uses the much =
simpler=20
libcurl to do that. Since WMS support is clearly an active, =
ongoing=20
development area, it's worth it to make the change now and avoid the =
libwww=20
process.</FONT></SPAN></DIV>
size=3D2>We=20
problem=20
you've having with the images - certainly, if you're adding other data =
on top=20
and need more palette space, moving up to 3.7/GD 2.x will be a big=20
improvement.</FONT></SPAN></DIV>
size=3D2>We=20
customers. =20
They are not free. Given the considerable expense involved in =
providing=20
this data online, we think they're pretty affordably priced, but they're =
not=20
"cheap". The DRGs are much less expensive than the DOQQs. =
Unlike=20
TerraServer, the data we have available as WMS layers is full-resolution =
GeoTIFF=20
data as it is delivered from the USGS. The TerraServer imagery is=20
converted to JPEGs to save space, and that can make a noticeable=20
difference.</FONT></SPAN></DIV>
<DIV><SPAN class=3D875200416-14022003> <FONT =
face=3DArial=20
color=3D#0000ff size=3D2>- Ed</FONT></SPAN></DIV>
<P><FONT size=3D2>Ed McNierney<BR>President and Chief =
Mapmaker<BR>TopoZone.com /=20
Maps a la carte, Inc.<BR>73 Princeton Street, Suite 305<BR>North =
Chelmsford,=20
MA 01863<BR>ed at topozone.com<BR>(978) 251-4242 =
</FONT></P></SPAN></DIV>
<BLOCKQUOTE dir=3Dltr style=3D"MARGIN-RIGHT: 0px">
<DIV class=3DOutlookMessageHeader dir=3Dltr align=3Dleft><FONT =
face=3DTahoma=20
size=3D2>-----Original Message-----<BR><B>From:</B> Brian Fischer=20
[mailto:bfischer at mpls.houstoneng.com]<BR><B>Sent:</B> Friday, February =
14,=20
2003 9:40 AM<BR><B>To:</B>=20
mapserver-users at lists.gis.umn.edu<BR><B>Subject:</B> [Mapserver-users] =
WMS=20
client layer and TerraServer<BR><BR></FONT></DIV>
<DIV class=3DSection1>
<P class=3DMsoNormal><FONT face=3DArial size=3D2><SPAN=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial">I would like to add the=20
TerraServer WMS as a layer in an application, but I am not sure what =
version=20
and compiled support for MapServer I need to make this work. I =
am=20
currently using 3.6.3 and I know it does not work with that =
version. =20
Will I need to upgrade to 3.7 or will 3.6.4 work?</SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial"></SPAN></FONT> </P>
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial">Is anyone else =
successfully using=20
the TerraServer as a WMS layer? I know there have been past post =
that=20
said it works with 3.7, but unless you are using GD2.x the image does =
not look=20
the best. Are there any other free sources or very cheap sources =
for=20
USGS DOQ’s and DRG’s as a WMS Service?</SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: =
Arial">Thanks,</SPAN></FONT></P>
Arial">Brian</SPAN></FONT></P></DIV></BLOCKQUOTE></BODY></HTML>
------_=_NextPart_001_01C2D444.9AF7C6D0--
