[Mapserver-users] Code of PHP CGI Program Displayed
William Carty
admin at thinktankdecoy.com
Sun Feb 16 01:38:09 EST 2003
(Lists Truncated)
Toshimi Minoura wrote:
> Hi All,
> We are trying to make MapServer 3.6.4 work with PHP
> on RedHat Linux 8.0.
> We placed the CGI program php in /var/www/cgi-bin.
> Another CGI program in this directory is correctly executed
> as a CGI program,
Another program using php as cgi, or an actual cgi script?
> We then aded the lines
> Action phtml-script /cgi-bin/php
> AddHandler phtml-script .phtml
> to file /etc/httpd/conf.d/php.conf.
> Now, when we select a .phtml file on a browser,
> the binary code of the CGI program php is displayed,
> instead of php interepreting the .phtml script.
> We also tested the following combination
> AddType application/x-httpd-php-cgi .phtml
> Action application/x-httpd-php-cgi /cgi-bin/php
> and got the same result.
> We will appreciate any help.
> Toshi
> P.S. If the answer is posted to mapserver-users, please send
> me a copy directly. There are too many messages posted
> on that list each day for me to read.
Personally, I'd highly recommend you drop what you're using now, go grab
apache & php sources & compile them yourself. I'm really not sure, as I
normally roll my own, but the php rpm included with RH8 may not have
been configured to run php as a cgi. Again, I'm not sure one way or the
other, guess it depends upon your answer to the question above.
You may try the following in httpd.conf, this works for me:
<VirtualHost *>
ServerName gis.ttd.local
DocumentRoot /usr/local/apache/htdocs/gis
AddType application/x-httpd-php .phtml
ScriptAlias /cgi/ "/usr/local/apache/htdocs/gis/cgi/"
Action php-script /cgi/php
AddHandler php-script .phtml
</VirtualHost>
Of course, there may be other issues to deal with. My understanding has
been that there are some issues between php & apache 2.x. Can't speak
to that, as I'm still using apache 1.3.27.
Another thing, what are your permissions on the php binary / symlink?
Good luck.
Will
